Question about Jandy Laars Lx 400,000 Btu Heater
Heater keeps going off
Heater gets really hot and the hot side of return starts to leak. when i shut down the heater the leak stops. the heater also make a banging noise and display says heating and then heating goes off but the burners are still on.
    Champion:
  • 246 Answers
Check the valve assembly may be bad if not the heat exchanger is plug nothing you can do about this
Posted on Aug 19, 2009
I have water leaking out of left hand corner of water fall and steps going into hot tub i think it is leaking only when pump is on
Sounds like maybe the clamps have given way on your water fall return line and maybe your ozonator return. You will unfortunately have to take down the wall to get access. Check all of your unions and make sure they are tight, and then look for pools of water to show where the leaks are. If your completely insulated with spray foam look for saturation that will lead you to your leak. Once you fix the leak make sure to spray foam over your repair. How To Fix Leaking Hot Tub
May 20, 2015 | Pool & Spa
Monitor heater keeps shutting off why?
78 olds uses a push and pull water controle on the heater hose. Make sure that the cable is working the water valve on.the heater hose. If it is working the valve back and forth then its most likley your heater core stopped up.. take both heater hoses off at the motor. Take your garden hose and flush water threw heater core. USE LOW PRESSURE.. DO NOT TURN YOUR GARDEN HOSE.ON FULL BLAST.. IT COULD MAKE THE HEATER CORE TO START LEAKING IN SIDE YOUR CAR. With.low pressure run water in each.heater hose.till water coming out looks clean. If this dont get you heat. Then check.your thermastat it may be stuck open.
Nov 23, 2014 | Heating & Cooling
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
Heater in my 2002 jeep wont get hot unless going down the road and I have water in the floor on the pasenger side.
Sounds like you have a leak at the heater core and lack of heat usually means low water level in radiator. When engine is cold ,add some radiator "stop leak" top up the radiator, start the jeep but leave the cap off until the water is hot and you are sure radiator is full. Then tighten cap and drive or idle for about half hour or more. When you can afford it change out the heater core.
Nov 23, 2010 | 2002 Jeep Liberty
Water leaking from the base of the tank
If you'r really lucky you may find a leaking fitting on top of the water heater thats draining down inside the shell and out the bottom, otherwise its time to replace a rusted out water heater.
Sorry
Nov 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Cooling system problem
well it might overheat because air got into system, replace the thermostant and then fill system, run van keepin an eye on the temp, it will start to run hot because coolant has not filled the motor just the radiator, when it starts running hot shut it down, wait 3 minutes and start, now this is done with cap off,after restart coolant should get sucked in get filling radiator as needed,may get messy but got to bleed cooling system. hope thius helps.
Jan 10, 2010 | 2001 Ford Focus
I have a really strange problem with my Nissan 2006 Pathfinder. The heater will not heat up and blow out hot air as long as the vehicle is sitting idling. When I want to defrost the windshield on frosty...
Since your blower is working and it is a heat issue,thats where we'll start,First thing is have you checked the coolant level in the radiator when engine is cold,make sure it is filled to top,next verify you have coolant in reserve ,Start your van and get it up to normal operation temperature,If your heat gauge on the dash works correctly it should be 190 degrees,Now lift the hood and locate the two heater hoses going into the heater assembly at the fire wall,Both hoses should be hot to hold on to,if both are hot and no heat inside your problem will be the blend air door in heater assembly.
if neither hose is that hot you need to replace the thermostat in the engine to get it up to 195 degrees.
if one hose is hot and one is luke warm then the heater core is blocked and to blame. hope this helps y
Jan 03, 2010 | 2006 Nissan Pathfinder
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
2001 pontiac montana heater is now blowing cold
You need to check coolant level in rad, when cooled down, and top up your return bottle to marked level.
Start by having coolant (antifreeze) ready, remove your rad cap, and top up the rad level, then start the vehicle, and turn on your heater (not defrost) . Let it run with cap off for a while, and keep an eye on level of the rad & top up as necessary, but leave an inch or so from top.Let it run & observe your guage while doing so, and when gauge gets to normal operating temperature, your rad fan should come on, run for a while then shut off for a while, then back on again after little while, and off again. Let it do this about 3 times, top off the rad as described above, put cap back on tight, and top up your coolant return bottle to mark on side. If your rad fan doesn't come on around normal operating temperature, and gauge heads too much towards hot reading, shut vehicle off, that's an indication that your rad fan fuse has blown, or relay, or fan itself is defective. If all works well & you now have heat, great, but keep an eye on your coolant return bottle level for next while to see if it keeps going down, and add as needed if it is. If the level in bottle continues to go down, you've got a leak in the system somewhere & need to address it a.s.a. p. to hopefully avoid bigger problems, but we'll get to that only if we need to. Do what's up above and let us know the results.
Jan 11, 2009 | 2001 Pontiac Montana
Jandy Laars Lx 400,000 Btu Heater Logo
131 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
