Question about Dell E173FP 17" LCD Monitor
Dell E153FPd Power stays on but video goes off after 2 seconds.
Video displays clearly every time I switch the power on but goes blank after 2 seconds. I've connected it to 3 pcs and it does the same thing on all of them. Any ideas please?
  • 30 Answers
3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
Posted on Jul 21, 2009
Video blanks out, power light turns off, power supply shut down
There are bad capcitors in the control board, there are bad tact switches on the control board,or the CRTs are leaking fluid onto the printed circuit boards Good Luck
Jun 21, 2007 | Hitachi 61HDX98B 61" Rear Projection...
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FP 17" LCD Monitor Logo
534 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
