Question about Boating
How to nfind a gear ratio ?
I have a 1990 Mercury Blackmax 150, it is a V6 and has a 4 3/4 in bullet 25in shaft which is frozen. I can't turn it to see what the gear ratio might be, is there another way to determine.?
Gary
    President:
  • 1,776 Answers
Count the number of teeth on each gear and divide. Example: If gear (a) has 60 teeth and gear (b) has 20 teeth, then the gear ratio is 3:1. Hope this helps.
Posted on Jul 21, 2009
What is ratio per gallon for mercury 150 v6
Hi Daniel!
Oil mix is 50:1 (Quicksilver recommended. Go figure!)
Here's a link to your service manual if you need it.
-Steve
Boatinfo Mercury Service Manual for 135 150 175 200 hp
Sep 09, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Differental ratio for 1990 nissan pintara
turn shaft 1 turn count other shaft turns
Jul 08, 2014 | 1970 Nissan Skyline
What years and makes of fords are interchangable with the rear end on a 1990 ford f-150
Depending on which rear axle assembly your 1990 F150 has....
Please indicate which is most applicable to your vehicles current axle assmembly.
ABS, 2.73 ratio
ABS, 3.08 ratio
ABS, 3.55 ratio
ABS, 4.10 ratio
w/o ABS; (Canada mkt), 2.73 ratio
w/o ABS; (Canada mkt), 3.08 ratio
w/o ABS; (Canada mkt), 3.55 ratio
w/o ABS; (Canada mkt), 4.10 ratio
Sep 28, 2011 | Cars & Trucks
1st 2nd 3rd gear whining noise but stops in 4th and so on,
this would be an internal bearing inside the gearbox on the input shaft......you have the shft coming in form the engine, and the input shaft houses 1,2, 3rd and 4th gears.....the 5th gear is located on an intermediate shaft.....and then you have the output shaft...now if you had said all gears i would have said output shaft bearing......and if you had said 5th gear only, then this would be the intermedaite gear.....
but you are only saying 1,2 and 3......why its not happening in fourth is that the gear ratios that the shafts turn in correlation to thre gearing changes as you get to 4, like on a 10 speed bicycle but in 4th it is a 1:1 ratio, so no excessive loads on the shafts are noticeable....
This will require a transmission overhaul......
Aug 26, 2010 | Ford Mustang Cars & Trucks
What is the gear ratios on a 1990 heritage soft tail 5 speed
Here are the stock gear ratios:
Gear Ratio (1): 10.11
Gear Ratio (2): 6.96
Gear Ratio (3): 4.95
Gear Ratio (4): 3.86
Gear Ratio (5): 3.15
Dec 21, 2009 | 2005 Harley Davidson FLSTC - FLSTCI...
Mercury 200 blackmax oil to fuel mix
Fuel oil ratios are,50/1. Eg.50 litres of fuel and 1 litre of oil. Hope this helps
Aug 29, 2009 | Furuno Navpilot 500 Designed for Use with...
Need gear ratio on 2005 F150 4X4 with axle code 19
here's a sure way. Jack up 1 side of the rear end, unless it's limited slip then both now with vehicle out of gear make a mark on tire at straight up. Now mark your defferintial behind the drive shaft is good or any where you can observe the results. Now turn tire 1 revoloution and have someone count hte revs of the drive shaft or deferintial. Most likely on that truck it will be 3 and a half turns or a 3.50 gear works every time especially if your hip on your axle ratio availability for the specific vehicle in question. Your fixed have fun! Dc
Jun 07, 2009 | 2006 Ford F-150
RPM's running alittle high at 60mph
ram1105: when you shift out of overdrive the transmission actually is in a 1-1 ratio with the input shaft of the transmission. Meaning for every revolution of the input shaft, the driveshaft turns the same number. When you shift to overdrive, the ratio changes allowing the engine speed and input shaft speed to slow down while the number of RPM's increases on the driveshaft shaft. The change is not too significant. Usually about a 500 RPM change is normal. You may have a problem with slippage within the transmission overdrive unit.
It may be advantageous to have the transmission pan dropped and it's contents inspected for debris. Older Nissan Automatics were not known for failures. The 3N71B was bullet proof and the 4N series which was just an overdrive added to it, were very reliable.
My son, best friend and I road race Nissan 300Z's. There are a variety of gear ratios for the R200 differential. The 3:70 is the tallest factory setup on a production Z, which would give you the lowest RPM at a higher speed. Outside of that, the tallest tires you can run on the car will also lower the RPM's.Don't forget there is always a trade-off. When you make a gear and change to taller gears, the car is going to feel more sluggish off the line. It will take longer to attain 0-60 unless you increase HP & Torque. I can help you there if you want to know how to do it.
Mar 23, 2009 | 1989 Nissan 300ZX
Gear ratio
There are two different ratios for a S10 Blazer,a 3.42(GU6) and a 3.08(GU4).Look in your glove box for a GM option codes.Look for a GU6 or GU4 code for the type of ratio you have.Hope this helps.
Mar 13, 2009 | 1990 Chevrolet S-10 Blazer
Boating Logo
85 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
