Question about HP LaserJet 4100 Printer
Black marks and words on paper
The print is ok, but I have black smudges and words paper, not a clean copy. Will putting a maintenance kit solve this problem?
    Scholar:
  • 71 Answers
Toner Black marks can only come from two places.
The toner cartridge or the fuser.
The best course of action would be to remove the fuser with the power off and line up a sheet with the problem with the fuser to see if possible to line up the mark and see if the fuser has a like defect in that position. I use inches but it is possible 79-80mm would be the edge of an envelope if you print them and I have seen instances where some envelopes over time cause a line on the fuser which then shows up on regular paper.
Hope this helps.
One more Method to sort out.
1. If a duplexer is installed, remove it. If a duplexer is not installed, remove the tray 2 dust cover from the rear of the printer by pulling from the bottom.
2 Remove the rear cover/rear output bin.
3. Rotate the two blue levers on the fuser assembly up to the unlocked position.
4 Pull the fuser assembly straight out of the printer.end chek de fuser.
5. When reinstalling the fuser assembly, be sure the blue levers are initially in the unlocked position.
6 Make sure the fuser assembly is seated fully before rotating the blue levers down into the locked
position.
Hope both informations will solve your problem.
Please have a regular maintenance agreement with local vendors for your printer to get serviced every month.
Best of Luck.
Posted on Jul 21, 2009
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
When you print anything, especially pictures, there are black smudges on the paper. They look like roller marks. I performed all the regular maintenance but it continues. If you touch these lines, they...
You may have a bad fuser. The fuser is the part of the printer that burn/melt the toner/ink onto the pager. Check the fuser roller and make sure it lock down and clean.
Jan 02, 2011 | Office Equipment & Supplies
The laserjet 3380 is smudging down the center of the print. tried cleaning mode, tried new cartridge
Depending on the # of copies you have on it...you may need a maintenance kit....(fuser)
Try stopping the printer (open the cover) when the paper is not all the way out and see if the smudge just starts when it is in the hot section (fuser)...if so, only solution is a maintenance kit.
Nov 06, 2009 | HP LaserJet 3380 All-In-One Printer
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Ink smudges on printed page.
I had the same problem when i refilled my cartridge. All I did to solve it was this: I removed the cartridge from the printer and cleaned the green cylinder with a very soft cloth. There is a cogwheel on both sides of the cylinder, so you can move the cylinder by turning the cogwheel. On my cartridge there were a few, hard ink-spots, i had to rub a little to wipe them off. When I removed them, the problem was solved.
Nov 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Phaser 8560 smudging problem
previous image on a copy are from two things
1-the blanking lamps that erase the image from the drum from the previous copy, and making it ready for the next image is bad
2- the fuser roller is bad and retaining the image on it.
Oct 08, 2008 | Xerox Phaser 8560MFP Laser Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Black mark on printed copies
Remove the black drum and see if see the line on the drum that you see on the paper---if it is replace the drum unit.. Good Luck
Aug 26, 2008 | Ricoh CL4000DN Laser Printer
Canon Pixma Ip4200 Ink Smudges
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Feb 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
HP LaserJet 4100 Printer Logo
241 people viewed this question
Seeker5211
Seeker5211
