Question about Amana 24 in. ADW862EAS Dishwasher
The rotating piece on the bottom of my Amana QT is not rotating
It seems as though the rotating piece on the bottom is not rotating, and the dishes are not being cleaned (worse on the top than the bottom). A repairman once told me that dishwashers are very basic, and really only have a few parts that need to be checked/replaced. Is this something I can troubleshoot/fix myself, or should I call someone in?
We bought our Amana dishwasher about 15 months ago. For the last three months it has been leaving the glasses streaked with soap (?) and the plates looking dull. sometimes I will get a glass that looks sparkling with others looking streaked or quite hazy. It also occasionally makes some strange sounds when it is washing the dishes. I checked the holes in the spray arms and they are not clogged.
If I could I would return it and go back to a whirlpool or kenmore.
Posted on Jun 20, 2010
    Sergeant:
    Champion:
  • 382 Answers
Check that the upper and lower spray arm nozzles are not clogged with particles if they are remove them a nd clean them out also see if there is a screen in the bottom of dishwasher under lower rack clean it out if you can also purchase a bottle of dishwasher cleaner from your local supermarket use it in a empty dishwasher first run tap closest to machine to make sure water is hot red directions on bottle it works very well and dishes will come out much cleaner also use a good gel like electra sol dihwasher gel
Posted on Jan 09, 2010
Fan not spinning on Amana RCB30B2A unit. Compressor is running though
It's the run capacitor for your fan. You'll need to pull it out and replace it. Look on Youtube about how to replace a condensing fan run capacitor. Make sure you get the same voltage and microfarad rated capacitor. Make sure you also disconnect the power to the unit. You can get the part at any HVAC parts house or Grainger. Should cost around $15
Jan 12, 2018 | Amana Heating & Cooling
My Amana Softsound 2 isn't getting dishes clean - the lower arm doesn't rotate. We cleaned around and under the arm as much as possible, got some gunk out from under, but still not rotating, so...
Check the nozzles of the arm themselves. if you found lots of gookl there maybe some inside the arms blocking the spray holes which cause it to spin
Jul 15, 2011 | Amana ADW862EA Built-in Dishwasher
My amana softsound III Model DWA63AL doesn't seem to get dishes clean. I have cleaned filters and everthing seems to operate ok. Water temp good. any advice?
Many people are having trouble with poor performance due to recent EPA changes required in dish washing detergent.
If it makes as much water splashing noise as it used to but it still leaves residue and undissolved food behind...then it's probably the detergent. That's what does the work.
Mar 08, 2011 | Amana DWA63A Dishwasher
Detergent is not all disolving and staying on the dishes...the dishes are not getting clean
Check inlet water availability. Check strainer attached to the machine body. Clean the strainer if clogged. Check spary arms for friction free rotation. Finally check the water pump inside machine.
Sep 20, 2010 | Amana Dishwashers
Spray arms not rotating
Check pump in the dish washer. Clean and check!
Apr 28, 2010 | Neff S5946 Built-In Dishwasher
Amana dishwasher, 1 "water on bottom and white film on dishes
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 30, 2009 | Amana 24 in. DWA53A Built-in Dishwasher
Ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Open Questions:
Amana 24 in. ADW862EAS Dishwasher Logo
277 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
