Question about Brother Black Inkjet Cartridge for LC31BK Printer
Refill ink Cartridge
Could you please provide me instructions on how to refill Ink Cartridge Brother LC51
  • Anonymous Sep 13, 2008
    i am needing help as to how to put the ink into the lc51 cartridge
  • Anonymous Feb 25, 2009
    Well, that link would be of great service, but I don't read German...
    I drilled a hole at the "well" at the end of the cartridge, but the ink only flowed into an upper chamber, not into the chamber where it needs to go...??
  • 832 Answers
See link:
http://www.hstt.net/refill-faq/brother.html#LC-1000%20-%20Doku
(the lc1000 is the same as the lc51)
Refill a max of 12ml for Y/C/M and 20ml for bk.
BTW
brother has changed the inside of the carts. So plz check carefully the pics if your cart looks the same. If it looks different you should drill the hole near the upper valve (the one with the white plastic)!
Posted on Nov 20, 2007
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do I refill Brother HC65 cartrige?
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Brother MFC 6490CW InkJet Printer
Ink
better use this generic ink carts, which work pretty much better than the original ones :o
http://www.tianma.net.cn/
http://stores.ebay.de/stonewaregmbh
(LC1000 is identical to LC51)
There is much trouble by refilling original carts, because of the ink which might clog the ph.
Anyway if you keen on inky-fingers, malfunction ph and maybe bad printing results:
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(use google translation german)
Apr 30, 2008 | Brother DCP 130C All-In-One InkJet Printer
Instructions on refilling cartridge for brother LC41CL cartridge
Do mix the ink with some glycerol to prevent clogging!
2ml glycerol (85%-glycerin alc. from drugstore) with 10ml of ink for C/Y/M and shake well (mix) before use. Mix 1,5 ml glycerol with 20ml BK ink.
Simply drill a hole into the brandname (O of brother) on top of the cart. Refill with 12ml for C/Y/M and about 21ml for bk.
You can leave the hole open.
Next time when cart is empty simply open scanner and refill without taking the cart out! ;-)
DO MIX THE INK WITH GLYCEROL!!!
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
REFILL INK
Is this a question about refill ink? With Brother and Canon original inks, they use a special type of ultraviolet ink for their ink level sensors to detect. I wouldn't recommend using anything but the original because of shortened printhead life. I have had many repair requests because of aftermarket inks....
Dec 02, 2007 | Brother MultiFunction Center MFC-440CN...
274 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
