Question about Canon PowerShot S2 IS Digital Camera
I can view prior photo's taken but. it will not take pictures. view finder is black
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 22, 2009
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: view finder is black, acts like it takes picture
This sounds like you're having a problem, either with the shutter mech inside the lens assembly, or else the CCD is not functioning. The unit will have to be serviced, unless you can free up the shutter assembly. You might try blowing compressed air inside the lens assembly, or bumping the camera slightly, on the side, in the hope of freeing up any dirt, lint, or sand that may have worked its way inside the assembly.
Other than that, the camera will have to be serviced. Here's Nikon's support site:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Good luck, and hope this helps.
Posted on Oct 31, 2010
When I look through hole to take a picture, nothing is there, just black, on my Samsung galaxy mega
Cell phones do not have view finders. Please click on the photo app for your phone. The screen is the view finder which you'll use to take a photo. samsung galaxy mega video Bing video
Jun 03, 2016 | Samsung Cell Phones
The viewfinder is black when I try to take a photo but \i can still view previously taken photo and all the date/time etc,., info is on the view finder
Some thing is wrong with the electronics that send the image to the viewfinder when you compose a picture. Not good especially if you zoom in and aim is off.
That camera can be repaired but is it cost effective to do? The parts are proprietary and the labor on those things is extensive. Unless it is a very expensive piece of gear, you might just be better off replacing it.
Nov 21, 2015 | Cameras
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
No picture on view finder
you need to request to replace your lcd unit to the service center.there's no chance to repair LCD.
Jun 03, 2010 | Olympus FE-280 Digital Camera
Fuji FinePix F710 photos blacked out
hi
i think the settings on the exposure or apparture have been modified
reset the camera to factory defaults once to check this and you can have the photos back in order
happy clicking, enjoy
pls rate if this was any help
Jul 13, 2009 | Fuji FinePix F710 Digital Camera
LCD screen is black when in photo-taking mode
hi
try chaning the menu options to LCD instead of View finder and things should get back to normal
if you are not too keen about the setting then you can just reset the settings to factory defaults and this should work again
hope this helped
cheers
pls rate the solution, thanks
Jun 28, 2009 | Canon PowerShot A75 Digital Camera
LCD on - view image prior to taking photo
The feature you are referring to is called "Live View mode".
This is NOT available on the Nikon D80, and was only introduced on the D90, which is available now.
Live View mode allows you to use the LCD screen as your view finder instead of using the eyepiece, but unfortunately, this feature is not available in your model.
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
D70s lcd screen is black
The D70S is a SLR (single lens reflex). You cannot use the LCD for taking pictures like the small compact digital cameras. There is no way for the CCD sensor to have any image prior to taking since it is behind the mirror and the shutter is closed.
Jan 20, 2008 | Cameras
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
