Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
KERNEL_DATA_INPAGE_ERROR there is one problem in my laptop it automatically get off and showing message KERNEL_DATA_INPAGE_ERROR with blue screen and then i press power button to off the laptop and again start it mostly happened when i copy CD (image CD), large file from external hard disc, run some software and other program together, sometime it makes sound near the fan i run Chkdsk /f /r verifier.exe command but the problem is as it so please tell me what should i do now? Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 169 Answers
Hey i think the kernel file of the computer has gone bad ,kernel file is the file that helps the computer to boot ,,,,,i would request you to go ahead and make a parellel installation of the windows in this you wont loose any data but all the corrupted file of the computer can be repaired by this process
Posted on Jul 22, 2009
Computer clicks then shows the kernel data inpage error screen
I'm sorry to say but that sounds like a hard disk failure. Classic symptoms.
Run a diagnostics test using Seatools:
SeaTools Seagate
Mar 21, 2014 | ASUS Silver 15.6" Vivobook V550CA-DB71T...
Had blue screen on laptop took advice and put laptop hard drive in Samsung drive enclosure My desktop can see the drive but I just get the message 'error performing inpage operation' Does this mean my...
Click RUN and cmd then you'll be in command window - then type chkdsk [drive:] /F (such as - chkdsk e: /F) which should perform a repair
hope this helps
Dec 04, 2010 | Samsung HM060HI Hard Drive
Drive Smart Read Error / Kernel Data Inpage Error/1000-0143
have you restarted the PC? If you have and it works, then this error is NOT too much to worry about... As long as the drive is Booting for now you can copy off your files etc to say a USB drive... You do not need to copy the programs etc, usually you simply copy over your "My Documents" or "Users" directories. As all files saved are generally "Under" there if you have any, anywhere else of course you need to get them as well. Now the drive may NOT be totally "Ruined" it may simply require a Re-Format, and then replace the Operating System. After which you can restore your settings. Below is a Microsoft link that tells you how.www.microsoft.com › ... › Computer Setup and Maintenance -
Either with the "Old" drive or a "New" drive. set BIOS to boot from CD/DVD and put the Windows Install DVD in the drive, boot of this and follow instructions, when you come to the place to partition & Format, do this and do a full NTFS format... after which your system will be installed and you can load your drivers and programs again Also before doing all this go to the manufacturers web site and download ALL drivers for your model PC & Operating System. You need to do this so you can install the drivers for all your Video, Sound, WiFi network etc. after you install your operating System
Mar 08, 2010 | Dell Inspiron 2200 Notebook
Blue screen error message (Crash Dump)
kernell has over run the memory....
some corrupt registries may also cause this issue...
u can try to run a registry cleaner (Tuneup Utilitis or Registry defrag etc can do the job...search in google)
else
do a clean install of OS after data backup
Dec 14, 2009 | Computers & Internet
The hinge is loose (there is a lot of Play ) and it goes to a blue screen with a kernel stack inpage error or black screen when i try to move the screen
Please stop using the laptop and have it serviced. You may be able to fix it yourseff if you're mechanically inclined and get yourself the service manual from Dell. I got mine for my Inspiron 9100 for about $10 from eBay.
The wires that feed the signal to the screen are located in the hinge area, and using the laptop in this condition is probably shorting the wires, causing the blue screen of death.
Aug 21, 2009 | Dell Inspiron™ E1505 PC Notebook
Kernel stack inpage error
Hi Janhams,
Unfortunately the screen you are seeing has a name for it "the BSOD" or blue screen of death (click here for more info). by your description of the clicking sounds id say that it is an intermediate to serious hardware problem, but there are so many reasons for the BSOD that its hard to nail it down to just one.
That said the BSOD can happen because of conflicting software and/or hardware failures. Think back a bit and try to remember if you put any new software on the pc before this started happening. If you did, try uninstalling that software.
If the answer is no then:
If it were my PC as soon as i see the BSOD I would replace the RAM memory and wait to see if it happens again. You can find the RAM just inside the CPU its an easy job (couple of screws and your done) and i can walk you through it if you like.
If it did happen again I would reformat the hard drive and again wait to see if the BSOD shows its ugly head.
If you follow the two steps above and you still get the BSOD then you know that its a more serious hardware problem and needs some hands on maintenance by a professional.
If you choose to reformat and want to do it yourself please click on my profile and ask me How do i reformat.
Nov 12, 2008 | Computers & Internet
Error performing inpage operation
I've just fixed the problem of error performing the inpage operation by using old DOS command CHKDSK <driveletter> /F. And, i'm satisfied with the MS-DOS command.
Jun 18, 2008 | Computers & Internet
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Kernel data inpage error
It is best practice with a used computer to completely format and
clean-install Windows. In your case, this is what you definitely need to
do after performing some hardware diagnostics. Here are links that will
show you how to do a clean install and what you will need on hand:
http://michaelstevenstech.com/cleanxpinstall.html
http://www.elephantboycomputers.com/...alling_Windows
Jan 02, 2008 | Toshiba Tecra M1 PC Laptops
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
233 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
