Low b+ (ocp/ovp) which part do i replace for sony kv40xbr800.
  • taeikchung41 Jul 22, 2009
    sony kv-36xbr800 6 times blinking error, which part do i replace.
    low+b ocp/ovp kv40xbr800, which parts do i replace.
  • 453 Answers
The part which could have gone faulty is
+5 volts line is overloaded (A,B boards)
+5 volts line is shorted (A,B boards)
IC6007 is faulty on A board.
Posted on Jul 22, 2009
    President:
  • 1,714 Answers
Low battery, check or replace
  • 3,037 Answers
Unfortunately, just about any problems on the low B+ lines will generate this error. I've run into several situations where the tech has replaced all of the boards and the problem remains.
It is usually one of the deflection yokes and if not that, one of the video drivers
on the C boards. Unplug the yokes (CN017, CN018 and CN019 are the numbers I believe though they may be different) one at a time while turning the set back on to isolate the defective yoke.
NOTE: Disconnect the C boards from the tubes to avoid phosphor damage.
Let me know how this turns out.
Benjamin
Posted on Jul 21, 2009
  • Benjamin Patri
    Benjamin Patri Jul 22, 2009
    You need to diagnose it more, I told you to start by unplugging the yokes, if you have no electrical expertise, I suggest finding someone who does so that they can do this. This is a dangerous and expensive tv to be working on and the error code will not specifically say which part but will give a general area where you can find the problematic part.
Kv40xbr800 2 flashes
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
For more details, visit the site
Electro-help. Type in the site name, in the search box of your Google or Yahoo search engine, and click it to open.
May 11, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Tv does not come on and the power light flashes 6 times
I'm not entirely sure what that means, but this website says: 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
It sounds like it will need warranty work. You can always try unplugging it and waiting 5 minutes and plugging it back in.
Please don't rank me low, I'm not an expert here, just trying to be as helpful as I can.
Mar 08, 2011 | Sony KP-51HW40 51" Rear Projection...
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Code light - 6 flashes
Go back to the site where you bought the chips and aks for help. If you did not buy a kit with help/instructions goto www.TvRepairKits.com and purchase their support only option. They can help you fix this
Apr 08, 2010 | Sony KP-46WT500 46" Rear Projection...
Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
replace the two mcz3001 ic's on the d or dz board, this is a common problem they have used this circuit for years, so the exact board number may be diffrent, but it will be located on the board with the flyback.
Sep 01, 2009 | Sony KP-53XBR300 53" Rear Projection...
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Kdf-55wf655 power led light blinking six times
Most Sony 6-blink codes for projection TVs follow this pattern:
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv just shut off and red light is flashing
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
6 flashes
also check out this sony recall
http://www.hdtvoice.com/voice/showthread.php?t=31861
Jan 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
