Question about Radio Communications
I have a rearview ICBM-9282. when car is on reverse appears a text: "Blue Tooth Connection" above 10 seconds. How know can I Program it in order to take off the text : "Blue Tooth Connection"?
  • 16 Answers
SOURCE: lg rumour and blue tooth
call the store adn they will tell you what to do or you can do it the old fashoned way and read the manual lol
Posted on Jan 03, 2009
SOURCE: blue tooth is charged but get a beeping sound
how good is phones signal mine does this when I have no service
Posted on Apr 11, 2009
SOURCE: samsung U 600 failing to connect to blue tooth conection
My daughter's Samsung U600 connects to her Clarion Alpine CDE 103BT radio OK, and she can call from the phonebook in the Clarion OK. However an incoming call shows up on the Clarion but then is immediately dropped. The chap who fitted the Clarion said it would answer calls automatically. Even if this wasn't the case and she had to press a key on the Clarion to pick up the call there wouldn't be enough time for her to do this.
Is this a Bluetooth connectivity problem or is there some setting that would correct this?
Posted on Apr 12, 2009
  • 192 Answers
SOURCE: blue tooth connection issues for photosmart c5500 using dell micosoft vista
You will need to have the ita drivers and have it where you do not need a secure conecsion and have the startup set to auto. Also make shure the printer is in descovery mode so that the computer can pick it up. Also make shure that the computer is in a good range from the printer so it can get a good conecsion.
Posted on May 21, 2009
samanthaj08
  • 570 Answers
SOURCE: Blue Tooth Connection instructions for a MT Max 4X Headset
Go to http://demos.blackberry.com/8300/na/us/gen/ >
Select "Menu" on the top left > Select "Start Using Your Device" > Select "Connect with Bluetooth Enabled Device"
Hope this helps :)
Posted on Oct 02, 2009
Hey, Trying to install a rearview camera in my 04 Sienna XLE and I want know if there is a reverse wire near the stereo. My instinct tells me I'm probably a few years to early on that feature, but...
take a 12 volt test light and check the wires at the shifter connection on the transmission,follow the one that goes hot when shifted into reverse. it should lead to a harness connection on the lower end of the steering column. but don't hold your breath. could also be inside console on floor shift models. any splicing must be done with same gauge wire.
Jul 29, 2011 | 2004 Toyota Sienna
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
Hi everyone. i just bought samsung link cell but i dunno how to use the bluetooth here. can you help me with this? actually, i tried to but the only command here is copy/move but it only copied/moved to...
before purchasing the phone did you ask if the phone has a blue tooth?.Because from the description you said your phone only send via multimedia message or text.
For a phone to have a blue tooth, in the send options blue tooth phone has three option which are multimedia message, text and blue tooth.
This is just an advice, if from where you bought the phone from they told you it was a blue tooth phone, you can still go back and make complains of the phone and tell them it is not a blue tooth enabled phone.
Have a nice day.
Mar 15, 2010 | Cell Phones
How do you wire a thermostat for heatpump electric heat
You should have at least 5 wires that are these colors and where they should go but may not be in this order.
Wire color - Connection (Wire Connects what)
  • White- W2 (Second stage Heat/ Emergency Heat) (elements)
  • Red- R (24 Volt supply to thermostat/ without this connected, nothing will work)
  • Blue- C (Common)
  • Green- G (Fan)
  • Orange- O/B (Reversing Valve)
O if reversing valve has to be energized for cool mode (YORK)
B if reversing valve has to be energized for heat mode.(TRANE)
Without knowing the unit model number or numbers. if it is a split system or package unit and which thermostat you are going to use. This is all the information I can give without knowing all the above. If this does not answer you question, reply back with the above info and I'll walk you through wiring the pieces together.
Oct 18, 2009 | Heating & Cooling
I need help connecting my blue tooth to my phone device
Hello
If you are referring to connecting your pone to your blue tooth device(dongle pluged into your computer?), you activate the blue tooth on your phone, plug the device into youre computer and right click on the blue tooth icon in the bottom right corner which will appear after a few seconds.
Click on ad device, your device will then search for other blue tooth devices.
Your phone must then appear.
double click on your phone, then you will be asked to enter a password. Enter anything and then next.
Your phone should now ask for a password then enter it.
Now the devices are paired.
Now just use the send via Blue Tooth function.
Hope you find this usefull.
Sep 13, 2009 | Plantronics - Bluetooth Headset Plus Base...
Display
try checking on the settings maybe you accidenally change the lighting schemes in your unit.
Oct 18, 2007 | Pioneer DEH-P6900UB CD Player
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
