Question about Panasonic Audio Players & Recorders
How do I replace the stylis on my panasonic turntable EPS 41st
  • Jeanie Dubois
    Jeanie Dubois Jan 04, 2017
    I figured it out. Thanks anyway.
2 Suggested Answers
  • 1157 Answers
SOURCE: seek replacement stylus eps 41st
Hi petermaud,
For you to obtain a New Stylus Needle for your Panasonic SLHM42, please visit this link.
Hope it helps.
Thank you for using FixYa.
Posted on Sep 15, 2011
What would it cost to purchase a styli/needle for Sherwood DEK7-U?
All you need to do is look at the cartridge and find the make and model number of it. Put that into google search and the information on the stylus should come up.
Jul 03, 2014 | Audio Players & Recorders
Technics sl-1200 tonearm problem
Hi, Assuming the the turntable is on a level platform and that you have "adjusted the weight and anti skating correctly", might it not be just the styli/cartridge that's left in question? Visually check the styli/cartridge assembly, look for unevenness of wear on the needle itself, compare with a known good styli the angle. On some rare instances, it is the shielded wire inside the arm. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | Technics SL-1200MK2 Turntable
Looking to upgrade the cartridge/styli in my ion audio profile pro turntable. What products/company/style should I be looking for?
I have the same turntable, and sadly the cartridge is proprietary and unable to be changed. However, you can still upgrade the sound quality by replacing the stylus to a higher quality needle. I did that for about $25 and feel better about playing my precious vinyl. The biggest problem to this turntable is the lack of anti-skate. That's very bad...
Mar 27, 2011 | ION Audio Turntable Cartridge Replacement
I have a Technics Hi-Fi System. My Record Deck
I have them listed on ebay as item 250390631634 for £7.25
Feb 09, 2010 | Audio Players & Recorders
Numark Pro TT2 turntable.
Try A New Cartrige And New Styli And Let Me Know The Outcome
Dec 05, 2009 | Numark PRO-TT2 Turntable
My turntables needle slides to the end of the record without playing.
is the stylis touching record.
what turntables have you got?
Aug 09, 2009 | Audio Players & Recorders
Turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Jan 06, 2009 | Audio Players & Recorders
STR8-60 stylus
I suggest you contact the MUSONIC web site. They specialise in cartridges and styli.
Dec 20, 2008 | Stanton STR8-60 Turntable
Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
Wrong type of stylis cartridge.
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
Feb 02, 2008 | Audio Players & Recorders
27 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
