Question about GPS
Over the past 30 da. our 4- person spa has not held air as it has multiple leaks (3/4), which we've tried to patch. Kindly replace as soon as possible. Thanks for your co-operation.
Buyer information: H.J. (Tom) Thompson, 45131 W. Balboa Drive, Maricopa, Arizona, 85139, USA Looking forward to your prompt attention to this matter. Dr. H.J. (Tom) Thompson, President, Olds College, Alberta, Canada
Trail0fDead
  • 36 Answers
SOURCE: tomtom one 125 map
The reason the 125 is cheaper is because it only has the US map on it. Each map contains an activation file that prevents it from being used on different devices, so its doubtful that the other map will work for you. You can purchase the latest Canada/Alaska map from TomTom's site for $59.95.
Go to
http://www.tomtom.com/products/maps/
Select your device as the ONE 130 (since they don't have 125 on the site) and choose the Canada/Alaska map.
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: I have power to the spa, but it won't power up
there are at least two separate circuit breakers feeding your spa and two reset buttons. the circuit breakers are located a few feet away from the spa in an electrical box.
the reset buttons are in the mechanical space of the spa where the pump and heater are located.
Posted on Aug 17, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
  • 990 Answers
SOURCE: Balboa vs500/501/502 gs500/501/502 I just refilled
A lot of times you can get an air lock as the spa fills. All you need to do to fix this is open the drain valve for a few seconds till it runs just water and no air. Or start the pump wile the drain is open. This should fix your problem. Good luck.
Posted on Sep 04, 2010
Air leak ring
patch with pool patch
Aug 11, 2013 | Intex 10' x 30" Easy Set Pool
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
I have 4 pin holes on my Intex pool. I tried patching from the outside..but water is leaking thru the patch.. What am I doing wrong? Can they be fixed?
Patch it from the inside. Get the special pool repair kit that allows under water patching. The kit I am talking about is superior to all others, expect to pay $12.00 . I use this kind of kit on my water bed though not from the inside.
Jun 04, 2011 | Intex Easy Set Pool 15x36
Air ring leaking on 18 foot pool....cant find leak...if it is the seam how do i fix it???
To be honest, ive seen 20-30 customers come to my company looking to fix this same problem. Weve tried vinyl patch after vinyl patch, and several different cement fixes. Nothing works.
The best results ive had are with a simple vinyl liner repair kit.
The most important thing is to let it sit for 48 hours before reinflating, but even this fix was only temporary.
Long story short, you get what you pay for, and intex is the cheapest pool systems on the market for a reason. The air ring always starts to leak right after the warranties are up, and the Intex company just plain out doesnt care.
Wish I had better news.
Mar 29, 2011 | Intex Easy Set Pool 15x36
Dear Sir, I have a 240 VAC 60 amp Spa GFCI panel, I believe it is a 4 pole The part FH-20J-4 is not working unless the spring load breaker is manualy held down. Where can i purchase this specific...
today is july 15, 2011. i just came across this problem today. i have a connecticut electric spa disconnect panel and the part fh-20j-4 went bad too. it was about 3 years old. the spring loaded breaker would not retract automatically like it is supposed to do. i had been doing work in my home which required me to shut off the main power a few times. the last time i shut it off, my spa didn't come back on once power was restored. i didn't find out until later that evening when i wanted to get in my tub. i checked it out the next morning cause i've had problems with the panel resetting a few times before after a power ottage. this time it would only work if i held in the spring loaded breaker. i called connecticut electric at 1-1866-822-0453 and told them about the problem and gave them the part number. the person took my contact information and told me she would send me the part free of charge. try calling them. the number listed above is to their indiana office. hope this helps.
Dec 29, 2010 | Connecticut Electric FPE replacement 2...
Everytime I try to play mw2 it asks me to download and install an update, is there anything to make this stop its the same update everytime. I do as it says and everytime I try to play the game the same...
I personally own the game and already had 4 patches.
I would recommend you to download these patches as they were designed to improve some of the online aspects of the game.
As far as I know there is no way to delete the update process as it is automated as soon as your logged into playstation network (PSN)
You could always start the game without logging into PSN and connect to PSN as soon as the game started.
I can see no point in not downloading the updates and they are only 15MB so it should not take too long to download.
Hope this helped.
Nov 17, 2009 | Activision Call of Duty 4 Modern Warfare...
Booster pump for cleaner runs for 30 seconds and then seems to power down and loses pressure tough still running. seems lots of air comes out so sweep stops running
you have an air leak where is getting this air from wll is fron the 3/4 inch line in front of the pump the line goin in this line is loose but don't try to cut the pipe and put more teflon tape because this pipe got hot and now it won't fee tied is always better to replaced I was a pool techinicial in california now I have move to Georgia so I know this verrywell
Jun 14, 2009 | Polaris Pb4 - 60 Booster Pump
I have a coleman spa about 4 years old that is leaking, should this be repaired by a plumber or would it take a spa repair person. it is a 6 to 7 person tub coleman horizion
this has to do with where the water is coming from.
1. wall fittitng. just remove it, reseal and replace
2. pump leaking, usually means shaft seal.
3. plumbing fitting. usually just replace the fitting.
4. fiberglass cracked. get a boat repair man and have him fix it. these guys are usually pretty good.
David
May 18, 2009 | Pool & Spa
GPS Logo
26 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
