How do i change the thermostat - Heating & Cooling
    Master:
  • 946 Answers
Hi Rhonda Henderson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? WHAT exactly are you working on and why are yu sure thermostat is bad? don-ohio
Posted on Jan 05, 2017
What size wrench do I need to change the thermostat on a 2002 diamante
Were is the thermostat on a 2002 mitsubishi diamante 3.5 v6 ...
www.fixya.com/.../t15150678-thermostat_2002_mitsubishi_diamante_3...
Nov 26, 2012 - SOURCE: asistance to change the thermostat in a 2002 mitsubishi ....size wrench do I need to change the thermostat on a 2002 diamante.
change thermostat change thermostat - Fixya
www.fixya.com/cars/t19454162-change_thermostat
Aug 16, 2013 - change thermostat - Mitsubishi 2002 Diamante question. ... What size wrench do I need to change the thermostat on a 2002 diamante. May 29 ...
Unanswered Mitsubishi Diamante Car and Truck -Q&A
www.dqrkc.com/cars/mitsubishi/diamante/problems
Mitsubishi Diamante - Unanswered Questions, Problems & Issues. Ad ... What size wrench do I need to change the thermostat on a 2002 diamante.
May 29, 2015 | 2002 Mitsubishi Diamante
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
The Toyota Camry engine light is on. Error Code P0125
Change bank 1 sensor 1 this will solve your problem. Tihs is a fuel issue nit a thermostat issue.
Jul 04, 2009 | 1998 Toyota Camry
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Can't get coolant flow after changing the thermostat
You will need to Change the Water Pump. It is still pumping, Just not enough to get the Thermostat to Open.
Jan 20, 2009 | 2001 Pontiac Sunfire
Rth230b thermostat, want to change C* to F*
Turn the thermostat mode to off. Push & hold both temperature up &down at the same time and screen on tstat should change and display Unit this is where you change C to F setting. I dont quite remember how to exit, if you change your setting and leave tstat alone and it should change automatically Good luck
F
Jan 08, 2009 | Honeywell Programmable Thermostat Heater
Changing a thermostat in a 1997 Oldsmobile Cutless
The thermostat is on the intake by the exhaust cross over. The crossover will have to be removed to get the thermostat housing out. If the intake gaskets are leaking fix them and change the thermostat while the intake is off. The only reason I say this is because the intake gaskets are a common problem.
Dec 27, 2008 | 1995 Buick LeSabre
Follow the big water hose on top of the radiator to the engine blogk. Where it goes into the block there should be 2 or 3 bolts to remove the housing. When you change the thermostat you should also change the gasket. I hope this helps.you.
Dec 07, 2008 | 1991 Toyota Camry
2004 jeep liberty thermostat change?
ihave to change my thermostat in my 04 jeep liberty is it hard
Oct 06, 2008 | 2004 Jeep Liberty
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
