Question about Janome Sewing Machines
My machine is janome 802 . the tread tention part of it is a part that have 6 pices i want correct arrangement of them to put them as a combined pice in one place if you have its arrangement
5 Suggested Answers
SOURCE: Janome 9000 top tread breaking changed needle, checked feed through several times
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Posted on May 30, 2012
99rannellis
  • 11214 Answers
SOURCE: Needle clamp
Hopefully, it was not stripped. If so, replacement is most likely the resolution.
Posted on Jul 10, 2016
99rannellis
  • 11214 Answers
SOURCE: the top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Posted on Dec 08, 2016
  • 102366 Answers
SOURCE: Can any body send me the instruction manual of Janome 802 sewing machine in PDF format?
We can't email it to you since you didn't publish your email address, but you can download it at http://janome.com/siteassets/support/manuals/economy-models/inst-book-7318-english.pdf
Posted on Mar 28, 2017
How do you thread a model 802 overlocker
Unfortunately, the only model 802 I can locate is a Janome sewing machine.
Search the internet for:
Make Model manual
or contact manufacturer support.
Nov 24, 2016 | Sewing Machines
Needle clamp
are you turning it clockwise when viewed from behind the head of the screw?
Remove it completely and practice, put it back in the right place and repeat.
Jul 09, 2016 | Sewing Machines
I have a Janome 802 swing machibe.I want to uninstall it for detail check and better service and then install it. I'm looking for a prorper service manual
Loosen the top cover the add a couple drops oil at each joint. Do the same for the rest of the machine. Remove the bobbin case and permit the sewing machine to run freely. It may take 10-15 minutes before it begins to loosen.
Feb 02, 2015 | Janome Sewing Machines
sounds like this machine may need a good cleaning as areas that are not visible can become clogged with lent, threads, etc. and cause it not to work and sound loud. I recently bought a non-working Janome for parts and wound up checking it out and found the gears were completely encrusted with lint, threads and who knows what else. I spent 2 hours cleaning the gear and she worked like a new machine after I did the cleaning and then reset the machine. It was the Janome Memory Craft 8000..I could not believe that little jewel had, apparently, never been properly cleaned.
My janome 802 sewing machine is giving a tough threading while i sew. How can i solve my problem?
hello can anyone tell me where can i buy a shuttle driver for my janome 802
Jun 28, 2012 | Sewing Machines
Not sure if i have put bobbin back in correctly, I have an old janome sewing machine. Also I havent used a machine for about 10 years, trying to remember.
with the brother its Pretty easy. you drop the bobbin in with the thread heading counter clockwise take your thread around the feed guide in a Clock wise manner then turn your knob it should pick the tread up fairly easily
Apr 07, 2009 | Brother XL3750 Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
