I have a 74cm sinotec crt tv with vertical line in center with no picture only audio
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Jan 05, 2017
My Sinotec LCD tv its having a problem when I switch it on it 1st gives funny red lines from there shows pictures halfly with dark picture on the bottom that can a day or two when it wants or some hrs...
Hi! this is jessie, i can help u solve the problem of your Sinotec LCD TV. Just check the following components inside :
1. Check only the horizontal and vertical section of your tv, look for possible cold solder inside .
2. Replace leaky filter capacitor or resistors due to overloading of voltage.
3. Be sure to unplug first your TV before troubleshooting to avoid electric shock. Thank you.
Feb 07, 2011 | Televison & Video
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Picture is compacted vertically in center of screen redgreenblue
your vertical hold is out on the tube. new tube is needed. cheaper to get a new flat panel tv.
Jul 19, 2009 | Samsung HC-P4752W 47" Rear Projection...
Sinotec lcd model Rc-N38,it does not have picture,but there is
I have a sinotec 32" LCD TV.when i put my tv on its shows me LCD TV in the center of my tv. and ofter screen is black
Jul 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
Mar 23, 2009 | Sony KP-46V35 TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Lighted line in center of tv
the trouble of your tv is not a picture's in vertical section,so check the supply of vertical IC if its ok ,re solder the ic.
Sep 30, 2008 | Emerson EWF2004 20" TV
Fly back lines
Check the connector of the crt maybe got a resistor open or a transistor in short circuit.
Jul 06, 2008 | Televison & Video
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
