Ihave a remote with code AVX1B4S on the back. It used to start my car. Now when I press the button the lights on the car don't even flash and the starter isn't working. What could be wrong?
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
SOURCE: remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Posted on Jan 11, 2009
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
  • 33 Answers
SOURCE: wii remote not working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 03, 2009
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
Sep 25, 2015 | Symphonic Televison & Video
Tip
Sony BDP-S360, BDP-S350 region free code
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S360 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
on Mar 07, 2010 | Televison & Video
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDV-E370 region free:
ok
Aug 08, 2011 | Sony Televison & Video
Need code to use dish network 3.0 IR remote with Magnavox h2160mw
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 03, 2010 | DISH Network IR Remote Control
Code For A Dish Network remote
Mar 01, 2010 | Orion STV2763 27" TV
Sky remote code
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Apr 26, 2009 | LG 37LG30 37 in. LCD HDTV
Need remote code for 22lv505 for dish network
Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
How to program your dish network remote for your tv:
1. Use the device’s buttons or its remote control to turn on thedevice.
2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
4. Use the number buttons to enter one of the device codes that I have given you.
5. Only for Limited Mode, Press 1.
Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
You cannot change the tv channel when the remote is in limited mode. You can only power on your
VCR in limited mode
****Note: Skip this step if you do not want to use Limited Mode.****
________________________________________________________________
6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
** Stop Here**
Let me know if this helps..
1388f48.jpg If I have helped you, dont forget to rate!!!
Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
RCA RCR 3273 universal remote
for codes:
http://www.rca.com/codefinder
Nov 27, 2007 | RCA Universal Remote 3 Device Remote...
Remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Nov 23, 2007 | Olevia LT32HVM 32 in. LCD Television
Dish Remote
I was given code numbers for the Olevia TV, 506 and 127....... they dont work for my 32" in my bedroom.
Nov 16, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
