Question about Dishwashers
Model sms40e18za new. Installed correctly. Starts cycle but never uses soap no matter what setting I chose. Brand new - please help
  • 883 Answers
SOURCE: Brand new dishwasher not working
try this test: add water (one gallon each try) by hand fill and try the cycle again. Continue until light goes out. If light never goes out, then faulty water level switch or wiring. If light goes out, then water inlet valve is stopping too early, but need more info to determine why. Try this test: open door and find the door switch. Then activate the switch and turn on machine to watch water come in. It should not just "dribble" in; try to determine if water pressure is sufficient coming in.
Posted on Jun 19, 2007
  • 1031 Answers
SOURCE: Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Posted on Mar 29, 2009
    • 10865 Answers
    SOURCE: soap doesn't dissolve no matter how many times dishwasher is on.i tried different soaps,we have a new sink and new disposal,but still nothing!
    It doesn't sound like the water is entering the dishwasher.
    There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
    2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
    If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
    Posted on May 08, 2009
    • 3247 Answers
    SOURCE: Soap doesn't empty from dispenser
    Assuming you are using the correct detergent powder, check if the dishes are remaining dirty.
    The water from the impeller may not be rushing up enough due to blockage or limited movement of impeller arm. Follow the insructions to clean the impeller, filter etc or check base of drawer for obstructions to impeller arm.
    Posted on Dec 12, 2009
    • 43501 Answers
    SOURCE: Soap does not dispense from cup.
    There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
    Dishwasher Repair Problem Detergent Cup does not Open
    Posted on Sep 30, 2010
    We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
    I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
    Oct 02, 2017 | Miele Dishwashers
    Westpoint manuals
    I've never had a microwave oven that dispensed soap. Are you sure you posted this in the correct area? Also, manufacturer, make, and model number would be helpful when you do repost.
    Jun 08, 2014 | Microwave Ovens
    Frequent leaks through soap drawer during rinse cycle
    Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
    click on : Dispenser
    Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
    Brand new whirlpool dishwasher starts on own
    Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
    May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
    I have a Beko DE2431FW Dishwasher which has stopped working. I select a cycle and then press start, the green light starts to flash and the cycle begins to start but after about 30 seconds it stops and the...
    Can be that you have a leak somewhere.
    At the bottom is a reservoir with a plunjer , wich switches everything off when this reservoir is full.
    This is to prevent , that your kitchenfloor gets wett
    Nov 20, 2017 | Dishwashers
    I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
    Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
    Mar 15, 2011 | Washing Machines
    My washer is brand new and it vibrates the entire house when it is on the spin cycle. It doesn't matter how much clothing or what spin cycle setting it is on. I've check to make sure that the unit is...
    If it brand new I would call back the service man or store I bought it from..From what your either has a powerful motor or the drum is out of balance with out any cloths in it....Put it in spin mode with nothing in it...If you get vibrations its one of two things...Either the whole washer isn't leveled correctly or its a unbalanced washer drum...Call them back and tell them either they come out to check it or you want it replaced....Be firm...It'd your money
    May 10, 2017 | Bosch WFVC3300 Washer
    Hot water goes into cold water washes
    It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
    During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
    Hope this helps, please rate my solution.
    Jan 12, 2009 | LG WM-1832C Front Load Washer
    Brand new to computers & blonde
    please visit the link below to download the correct driver for your printer directly from Lexmark.
    use the product selector to enter your model number and operating system.
    Sep 25, 2008 | Lexmark X2500 All-In-One Printer
    Dish Washer not cleaning
    white film generally shows that there is not enough salt in the dishwasher, this is not normal salt like on your meal, you buy this from the detergent section of the store, add salt through the part where it says "S" unscrew the cap and put about 2 cups of it in, while filling with salt water will overflow out of the same place, this is normal this will start to work after about a wash or so if the salt is fine then check the heater on the machine, make sure its warming up etc if i have helped please rate me
    Oct 03, 2007 | Dishwashers
    Dishwashers Logo
    32 people viewed this question
    Top Dishwashers Experts
