I need a wall bracket for our TV - Televison & Video
    Master:
  • 502 Answers
Many places that sell tvs will have them.
Posted on Jan 04, 2017
How do fit a wall bracket on 50 in techwood tv
TECHWOOD 50inches TV Wall Mount Bracket TV BRACKETS TV WALL BRACKETS...
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Semper Fi,
Z
Jan 30, 2018 | Televison & Video
What's involved in wall-mounting a flat-panel TV?
Actually, wall-mounting your TV is a pretty simple task. You'll need to buy the right bracket to fit the size of your TV and also meet the right distance range you want. The procedure is explaining in every bracket you buy and involves drilling a couple of little holes in the wall.
Jul 29, 2012 | Furniture
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
Can a sony bravia kdl-w40a12u be put on a wall thanks
You need to use GOOD WALL BRACKETS which can hold the weight of the TV.
Also the mounting on the wall must be firm with good foundation tower bolts.
please check on the links below for some tips and ideas on wall brackets.:
TV Wall brackets: http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Jul 28, 2011 | Sony KDL-W40A12U 40 in. LCD Television
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Feb 03, 2011 | Sony SUWL500 Wall Mounting Bracket
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
How to fit wall bracket to tv
the bracket should have instructions. the set will have screw holes on the back to bolt to the bracket.
more detailed info needs to come from the bracket MFG
Dec 05, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
