Question about Video Cameras
Hae can get an interface with usb port which can play mp4/3 on mynhzt-w58g
3 Suggested Answers
StuartB
  • 807 Answers
SOURCE: 2.0 USB External Interface Compatible w Compaq USB Ports????
USB 2.0 is just faster.
If you have USB 1.0 ports on the computer the new drive will revert to that speed.
Posted on Mar 07, 2008
SOURCE: how to use USB port
Hi
I know this was posted a while ago but i can answer your question.
Insert your USB drive or SD Card and turn on your dvd player. Grab your remote and press 'Switch' on the bottom left of the control. Select USB, Card or DVD from the list and hit Enter. Another little pop up will appear showing you that a device has been inserted. Just hit Enter again and it will display the contents. Select your file and press Enter or Play.
To switch back to the DVD you can either use the 'switch function again or just turn off, remove your device and turn back on again.
Cheers
Posted on May 11, 2009
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Mouse not detected
Make sure you have the mouse plugged in tight in the back of the computer before you start the computer.
There are two types of mouse interfaces: the PS2 Serial Style (round) and the USB Style (flat square).
If you have the PS2 round type it must plug into the Green Port on the back of the computer. The purple port is for the Keyboard. Also, the PS2 type is not Plug and Play. You cannot unplug it and plug it back in while the computer is running if you do the computer must be rebooted.
The USB type mouse is plug and play. You can take it out and put it back in without having to reboot the computer.
If you have a usb type mouse maybe the usb port that you have it plugged into is not working. Try plugging it into another usb port.
May 03, 2012 | HP Compaq 2230s Notebook
Motherboard specification
Intel 865GV Chipset Pentium 4 Main board,
Supports Prescott CPU
FSB800, DDR 400, SATA 150 Specifications
arrow_bullet.gif CPU
  • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
  • Supports Intel Hyper-Threading Technology
arrow_bullet.gif Chipset
  • Intel 865GV/ ICH5
  • Integrated Intel Extreme Graphics 2
  • Supports Advanced Configuration and Power Management Interface (ACPI)
arrow_bullet.gif Memory
  • Two 184-pin DIMM sockets
  • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
arrow_bullet.gif Graphics
arrow_bullet.gif SATA 150
  • 2 channel Serial ATA 150MB/s data transfer rate
arrow_bullet.gif Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports optical S/PDIF Output
arrow_bullet.gif System BIOS
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
arrow_bullet.gif LAN
  • On board 10/100Mb LAN
arrow_bullet.gif Internal I/O Connectors
  • 3 x PCI slots
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 2 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
  • 1 x CD-IN, 1 x AUX-IN
  • 1 x FP-Audio header
arrow_bullet.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Parallel Port, 1 x Serial port
  • 1 x VGA Port
  • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
  • 4 x USB 2.0, 1 x RJ-45 LAN Connector
arrow_bullet.gif Miscellaneous
  • Micro ATX form factor (244mm*234mm)
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    hope this helps
Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My SCD 103 Camcorder does everything BUT will not play back on my LCD screen, Computer or TV (With USB hook-up)....
This camera downloads video over a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software (even Windows Movie Maker will work). No driver needed.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Jan 10, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
Want to downlaod to computer via usb, but computer doesn't see device
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Nov 11, 2010 | Sony Handycam DCR-TRV27 Mini DV Digital...
What mp3 player will work in the usb port on the kenwood kvt-514?
You can put a USB thumb drive in this port, and it will play mp3 files from that drive.
You can also buy an iPod interface that will let you plug in an iPod or iPhone to the USB port.
Jan 27, 2010 | Kenwood KVT-514 Car DVD Player
How to use USB port
Hi
Cheers
Mar 26, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
USB
Hey Robo71-
Is the USB port located next to the aux ipod jack under the center console (factory installed), or is it in the glove box (dealer installed)? If it is dealer installed, it might not be properly connected...
Mini says that the aux input is easier to use, but the USB audio interface (SA 6ND, SA 6NE) supports the common compression formats MP3 (mp3), AAC (aac, m4a, m4b), WAV/PCM (wav) and WMA (wma, asf) as well as playlists in the M3U format.
The operation interface leaves a lot to be desired. I put a bunch of MP3 files on a USB memory stick I carry around, and plugged that into an 08 Mini at the dealership with the convenience package.
Lo and behold, a list of titles came up on the two-line display in the speedo!
(After a certain amount of button-pushing and gnashing of teeth. These people aren't going to win any awards for user interface design, at least the good awards.)
Turning up the OTHER knob (the unmarked one, you know, the volume knob) got music to play.
Mashing buttons on the Multi-Function-Steering-Wheel allowed me to change volume and go forward and back a track within the folder it had chosen to navigate.
Choosing ANOTHER folder to navigate was an exciting exploration, involving another round of seemingly random button pushing and knob twisting. SOMEHOW I got the thing to select another folder, and playing more music.
It looks like if you've got the USB connector, you can load up MP3 files on a cheap memory stick and play 'em. Good use of cheap memory sticks!
Hope this is helpful, good luck, and don't forget to rate my help!!! Your rating is my reward for doing this!
Thanks,
-WildBill
Jun 23, 2008 | Cars & Trucks
No Real Time Sound from USB Port in Headphones
The problem is due to the design of the DELL Laptop itself. It is not dsigned to monitor the incoming signal. I bought a cheap Behringer UCA202 USB-Audio Interface. It provides for real time monitoring the incoming sound. I can also hear the accompanying music while I play along with pre-existing tracks. It's not the highest quality but it was only 25$ so well worth the price.
Oct 18, 2007 | Compaq Presario Notebook
Video Cameras Logo
56 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
