Question about Miscellaneous
What can i do to finish my matric - Miscellaneous
Where do i go to restore my lost matric certificate
Certification Services - Department of Basic Education
www.education.gov.za/Informationfor/CertificationServices.aspx
  1. Cached
A change to an original certificate will not be considered unless the original certificate (not replacement) is returned. To change your name on your matric ...
Replace matric certificate ' South African Government
www.gov.za/node/727532
  1. Cached
  2. Similar
Apply for replacement of your matric certificate at the Department of Basic Education if you have lost or damaged your original matric certificate. You can request ...
Career Planet ยป Where can I get a replacement matric certificate?
www.careerplanet.co.za/where-can-i-get-a-replacement-matric-certificate
  1. Cached
  2. Similar
I lost my matric certificate. I damaged my matric ... Replacement (re-issue) matric certificate? I need a new ... (2) I damaged my matric certificate! What must I do?
Youth Village How To Recover A Lost Or Damaged Matric Certificate ...
www.youthvillage.co.za/.../heres-how-to-recover-your-matric-certificate-after-losing-i...
  1. Cached
Nov 26, 2015 - Please note: Applying for your lost or damaged matric certificate might differ from one province to another. Below is a guide to applying for ... restore my lost matric certificate Google Search
Jan 04, 2017 | Office Equipment & Supplies
I was attending private school i didn't received my matric results become i didn't finished to pay school fees
Its up to the school , no fees no paper work. You could see the school head master and agree to pay the fees , they may charge extra to do this.
Dec 20, 2014 | Office Equipment & Supplies
How to do matrix problems in fx991ms
The following was written for the Casio FX-991 ES. If matrix calculations are available on your calculator you will perform them as described below. ( I have no time to verify that the FX-991ms can perform matrix calculations).
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matricies, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match.
Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular umbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrice by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Nov 07, 2012 | Casio FX991MS Scientific Calculator
How to multiply the matrices using fx-991ms calculator
Nov 06, 2012 | Casio FX991MS Scientific Calculator
How to do matrix multiplication in scientifically calculator
Here is an account of what you can do with matrices on this scientific calculator. Certain precautions must be taken as concerns the dimensions of the matrices. Refer to your text book on matrix algebra.
On this calculator the largest matrices you can define have dimensions 3X3.
  1. First you must set Matrix calculation: Press [MODE][6:Matrix].
  2. Then by entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix (mxn].
  3. Once finished entering the matrix you clear the screen.
  4. The operations on A SINGLE matrix are available by pressing [Shift][Matrix].
  5. The choices are
  • [1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
  • [2:Data] enter values in a matrix
  • [3:MatA] access Matrix A
  • [4:MatB] access Matrix B
  • [5:MatC] access matrix C
  • [6:MatAns] access the Answer Matrix (the last matrix calculated)
  • [7:det] Calculate the determinant of a matrix already defined
  • [8:Trn] The transpose of a matrix already defined
Once you have created a square matrix, for example matA.
You press
[Shift][Matrix] [7:det] [SHIFT][MATRIX][3:MatA], close the parenthesis and press [ENTER].
If you have defined two similar matrices (same number of row and same number of columns) you can ADD them or subtract them. The operation keys are Plus and Minus as for any number.
To multiply you use the multiplication sign. The matrices must be compatible (mxn) multiplied by (nxk).
Aug 10, 2011 | Casio FX-115ES Scientific Calculator
How to use matrix in the calculator
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Aug 06, 2010 | Casio FX-115ES Scientific Calculator
How to multiply two matricies?
Mar 06, 2010 | Casio FX-115ES Scientific Calculator
Matrix
Here is copy of the answer I posted to a question on how to use Matrices. Read it carefully. It helped a few people, and there is no reason why it should not help you too. If after a bona fide effort to understand it you still have a problem, post a comment here. What I am saying, is do not just shoot the answer, try it first.
[MODE][6:Matrix].
  1. Then By entering one of the numbers [1:MatA] or [2:MatB] or [3:MatC] you get to choose the dimensions of the matrix (mxn)
  2. Once finished entering the matrix you clear the screen.
The operations on a single matrix are available by pressing[Shift][Matrix]. They are
  • [4:Matb] access Matrix B
Operations involving 2 matrices
  1. To add matrices: MatA+MatB
  2. To subtract: MatA-Matb
  3. To multiply: MatAxMatB
  4. To raise a matrix to a power 2 [x2], cube [x3]
  5. To obtain inverse of MatA already defined MatA[x-1] where [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match (see you textbook for the rules). Read the appendix to your user manual, there are several examples.
Jan 07, 2010 | Casio FX-115ES Scientific Calculator
How to do matrix multiplication on Casio 115ES?
Hello
Read the appendix to your user manual, there are several exemples.
Hope helps
Sep 10, 2009 | Casio FX-115ES Scientific Calculator
Miscellaneous Logo
27 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
Philippe Dekyvere
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
