Question about Kitchen Appliances - Others
I have a Ugolini Doble slush machine left side is making a clicking sound when it starts to freez
  • Anonymous Jul 17, 2017
    I have the same issue with my Ugolini slush machine. Does this occur when the slushie is starting to get thick towards the end of a batch? I have read it is the tension adjuster just calibrating itself.
4 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
projdoc
  • 2237 Answers
SOURCE: Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Posted on Jun 13, 2015
perkins48
  • 14417 Answers
SOURCE: How long the ugolini slush machine takes to finish slush drinks
Check this link out Adrian. Frequently Asked Questions FAQ SlushieCo
Posted on Mar 09, 2017
How do i know if thermostat is bad
depends on the slush machine. if it's a cab or ugolini, it won't go into defrost or it'll just go warm instead of refrigerated. easy way to test on a cab faby- put the timer on defrost when the product is not frozen, turn the right auger on then off. if the compressor did not go on and off, the thermostat is bad. same for a ugolini, but it'll work with both sides, so turn one off. if you have a bunn ultra 2, the display will let you know there is a thermostat issue. if you have a bunn cds 2, it works the same as a ugolini.
Sep 03, 2014 | Kitchen Appliances - Others
I have no power to my ugolini slush machine gear motors where can i check
if you open the back and check the leads on the motor with a voltmeter and you don't get voltage, make sure the switches are working and connected. if there is voltage and the motors spin but the auger end does not, one of the gears are stripped of the bushings are worn and the gears do not mesh. if the bushings are the case, you can remove the back of the motor, remove the gears, pop out the bushings and flip the over. they may be good enough on the other side. if the motor gets hot but does not spin, you'll have to remove it and clean it. if you have a ugolini non-magnetic (if the shaft goes all the way through to the auger), you'll also need new rear seals.
Aug 25, 2014 | Kitchen Appliances - Others
Why does my ugolini slush machine over freeze only on one side?
check your mix. if it's too lean (not enough syrup base), it'll freeze too quickly. if the auger stops moving when it's freezing, you blew a gear and it won't know when to stop freezing. also if the torque spring on the right side of the motor (through the back) is broken or missing, same thing.
Jun 27, 2014 | Kitchen Appliances - Others
Ugolini slush machines
check the left side condenser coils, make sure they're clean. there might be low air flow, and that'll cause the compressor to overheat and shut off. leave at least 6 inches of space on both sides of the machine for it to breathe. also if the ambient temp is too hot, same thing.
Jun 26, 2014 | Kitchen Appliances - Others
It will ne the thermostat for sure or switch is faulty Good luck
Apr 11, 2014 | Blenders
you need to replace the gear bushings in the auger motors. or if they're no too bad, you can just flip them and get more time
Apr 06, 2014 | Kitchen Appliances - Others
What causes_slow_freezing_in_slush_machine
check the airflow. if the condenser coil on the left side is clogged with dust, it won't chill. remove the side, clean the fins, and try again. also check the fan. if it's not moving very fast, replace it.
Apr 12, 2013 | Bunn Margarita Machine Ultra 2 Slush...
The left side of the machine is freezing, but it's pushing all of the frozen product to the top of the lid and overflowing
each side should only have 2 to 2 1/2 gallons of mix. there is a line on the bowl that is the max fill line. as it starts to freeze, the auger pushes the product to the front and up. if it's too full, it'll over flow. just empty some out.
Nov 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Kitchen Appliances - Others Logo
770 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
