Question about Neff Dishwashers
I know it is NEFF about 3 yrs old. dishwasher tablet not being used or even ejected correctly & often not even used. flap pops open during the cycle.
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
  • 228 Answers
SOURCE: Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Posted on Aug 05, 2009
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
I have a Neff Dishwasher S5443X2 and the dishwasher tablets are not dissolving. The tablet door is open when the machine finishes but most of the tablet remains. We tried using detergent but still the same...
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jun 27, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Adg450 about 5 yrs old. Beep Beep.....Beep
Hi, I have a very simular problem, I have just read that running the water in the kitchen sink until its hot may work, if not could you please let me know if you get an answer to this problem,
Thanks
Peter
Aug 01, 2009 | Whirlpool ADG450 Slim-Line Built-in...
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Hi!
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
