Just purchased a projection alarm clock yesterday--LOVE it! How do I turn the projection light off? I don't want to burn the bulb when it's not needed.
  • 281 Answers
SOURCE: Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Posted on Mar 03, 2008
SOURCE: Light on the projection is fading
if the led is fading it waring out and it will need replacing try and **** smith electronics or Radio shack take the clock in with you so they can provide better service for you
Posted on Jul 18, 2008
  • 77932 Answers
SOURCE: Clock light burned out
You will need to pull the clock, the bulb is on the back, any parts store will carry it, it is a mini peanut bulb.
Posted on Oct 02, 2008
SOURCE: alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Posted on Jan 23, 2009
SOURCE: change light bulb in night
  1. j23lynne.jpgjames carl
Posted on May 22, 2011
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
Blue hat toy company kids projection alarm clock instructions
I would love the pdf instructions sent to me. Someone gave my son of the rocket clocks by Blue Hat.
Jun 23, 2013 | Toys
Need a diagram on how to replace light bulb in clock in EL Falcon dash.
To replace the clock light bulb on 2001 Honda Accord, you will need:
  • Screwdriver
  • Replacement bulb
  1. Remove the clock assembly in the 2001 Honda accord. Pry the clock assembly off by wedging a flathead screwdriver into the edge and prying off the cover. Work your way around until it comes off.
  2. Remove the old bulb by pulling it out of the socket. Dispose of the bulb.
  3. Replace the bulb with an equivalent bulb. Simply push the bulb into the slot. Be sure to take the bulb with you when you purchase a new bulb so you get the exact bulb. Purchase a bulb with the same voltage. Although a bulb with different voltage may work, it can burn out more quickly.
  4. Replace the clock assembly. Line up the clock assembly over the bulb and press firmly on both edges to attach it back to the 2001 Honda Accord dash.
  • Place masking tape on the edges of the dash around the clock assembly to protect your dash while you are removing the assembly with the screwdriver. Remove the masking tape when you are finished replacing the clock light bulb on your 2001 Honda Accord.
Jul 05, 2011 | Falcon 4420
How do i turn the clock light back in? I lost my manual and know it is easy because i havedone it before, i just cant recall how to.
The clock back light comes on when the ignition key is turned to on. If the key is on and the parking and/or headlights are turned on, the clock back light becomes controlled by the instrument lights dimmer control knob on the left side of the instruments panel under the tachometer.
The clock back light bulb does burn out and is very difficult to change because the whole instrument gauge cluster must be removed for access. Many people I know who have purchased pre-owned Odysseys are under the impression that the clock does NOT have a back light for this reason.
Apr 01, 2011 | 2000 Honda Odyssey
The clock dial on my Malibu Transformer has begun rotating in reverse. Therefore, it cannot turn the lights on or off because it is going against the direction the switch moves. Any ideas what caused...
There are no fixes for Power Packs once they go bad.
"Harry" wrote in with a work-around: He purchased inexpensive plug-in timer, set power pack to override, and then plugged power pack into wall timer.
Harry also said his power pack gave out after 4 years and he was negoiating with for the 5 year warranty. No word how that was resolved.
Some guys write into fixya saying they took the timer apart and messed around with it, but I've never heard anyone say they fixed it. Once the little motors and gears malfunction, the motor slows down, and when motors slow, they overheat and lose power. New Power Packs at Home Depot are digital.
After hours looking for power pack solutions at Intermatic,, ebay, Home Depot etc, the best I found were tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on any do-it-yourself project.
Jan 11, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Window, interior lights, car alarm and fuse keep on burning out
you have a short circuit or burned out wires somewhere, could be anywhere.
Try disconnecting the alarm, taking the bulb out of the interior lights, and putting in the fuse, if it blows again you know that the alarm or interior lights are not at fault, if it stays good replace the bulb and if it blows theres your faulty circuit, if it stays good then the windows are at fault.
Oct 09, 2009 | 2000 Volkswagen Jetta TDI
No pic with sound and turn off by itself with a
The red light is a status indicator that means your tv needs to be serviced. Most likely your bulb burned out or failed. You can purchase a replacement bulb online. I have solved a few questions on how to replace a bulb on this site. Check my profile for those posts if you need help with that.
Jul 01, 2009 | Mitsubishi WD-60735 Projection Television
Disney Princess Alarm Clock Radio
I can not get the radion to work or the projection light to work. No instruction manual.
Sep 18, 2008 | Disney Princess Alarm Clock Radio
Color spots on panasonic projection screen
The light engine may be dirty with dust, the polarizer filter burned, or the LCD elements burned.
As a last-ditch effort, the light engine can be taken apart and carefully cleaned using compressed air.
Apr 12, 2008 | Panasonic PT-50LC13 50" Rear Projection...
24 people viewed this question
