Question about Pioneer Audio Players & Recorders
Replacing the stylus type 230 in the fixed cartridge of a Pioneer PL-340 turntable
  • 38 Answers
SOURCE: Opening Pioneer PL-600 turntable
Dear pap 55,
The feet are removable, can be open. To check the dead set you donot need to open it. Remove the power cord from the wall socket, check the contnuity with multimeter of the two pin plug after switching on power switch of the system.
ramesh22
Posted on Jun 08, 2008
SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
Magnetic phono cartridges like the one on your pioneer has an output of about .005 Volts, the standard inputs are looking for 1 to 2 volts for fulol out put, the phono preamp will step up the output voltage to 1 volt so you can play it thru a non phono input like Aux, tape or tuner.
Radio shack sells cheap ones and you will hear what you pay for.
I sell turntables and audio gear, check out www.soundsciencecat.com
Good Luck,
Neal Van Berg
Posted on Sep 16, 2008
dunnbiker
  • 8546 Answers
SOURCE: pioneer pl-200 turntable one channel is dull and muffled
I think we need to do more diagnosis. Did you try swapping the channel cables Left-to-Right so you're sure it is in the TT and not in your Phono preamp?
If it's still in the TT and always on the same channel with two different cartridges you probably have a wire problem in the tonearm/shell or interface between them.
Posted on May 01, 2009
19samtann61
  • 12 Answers
SOURCE: Pioneer pl 50 turntable it
Try changing out the capacitor on the underside of the platter. They will lose their rated value over time.......
The schematic shows a 1000 volt rating. I have three that I am referbing and all of them came from Pioneer with a 450 volt CAP.
Try replace it with one that is rated at least 450 volts.
Also - the closer the tolerance the better. See if you can find one that has a K rating, meaning it is +- 10%. The M rated ones are +-20%.
Posted on Aug 20, 2009
SOURCE: Where to get 12 volt power supply for Pioneer PL-203AZ Turntable?
+ is on center pin, and the current consumption is low, not more than 200mA. A 12V wall-wart will do fine.
Posted on Dec 23, 2009
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
I don't know what needle is needed for my pioneer turntable PL-X88Z?
You just need to look at the cartridge and look for the make and model number. Once you have that you can search Google for it and the stylus will also show up.
Sep 26, 2013 | Pioneer Audio Players & Recorders
About 11 months ago I bought an Elliptical upgrade stylus for the PL-990 and it worked great. Recently, it started giving me problems. The left channel would be very distorted and also would fade in and...
Very odd! Sounds like it's not fitting in right. Are you sure that you have the right type of stylus for the cartridge? If in doubt replace the entire cartridge & Stylus. If it still plays up then it's in your amp after that course of action.
Aug 18, 2011 | Pioneer PL-990 Turntable
I have Pioneer pl202az record player.. need help finding to replace the broken needle..
It is seldom worth just replacing a needle. It's not much more expensive to replace the whole cartridge. Easily available online - search by make and model number on Amazon
Feb 22, 2011 | Pioneer PL-990 Turntable
I suddenly heard alot of distortion when playing the Pioneer PL-990 turntable. Wonder if replacing the needle may take care of the problem.
Depends on the circumstances. Is it only when you play it loud? Air- or room-borne vibrations will feed back through the TT to the speakers. Keep the volume down to avoid it.
If you call the stylus a 'needle', replacing it maybe beyond your capabilities. There are lots of reasons for TT sound to be less than perfect and arbitrarily replacing things can do more harm or introduce new problems. Take it to someone experienced and equipped to evaluate the issue.
Tonearm balance, antiskating, dirty stylus, feedback.
Dec 28, 2010 | Pioneer PL-990 Turntable
Pioneer pl-200 turntable one channel is dull and muffled
May 01, 2009 | Technics SL-1210 Turntable
Trouble with sound
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Mar 13, 2008 | Pioneer PL-990 Turntable
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
