Topcon 802a Error 86 (E86) I turn on my Topcon 802a instrument and after about 20 seconds of startup it gives me E-86. That being said there is no data collector connected.
How do I calibrate a topcon laser ?
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series. calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-0.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-2.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-5.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-9.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-14.jpg
Aug 11, 2014 | Topcon Rotating Builders Red beam Laser...
Why GTS-102N can not read prism
These are actually high maintenance items and require periodic cleaning and calibration from the manufacturer or authorized service center.
Jun 08, 2014 | Topcon GTS-102N Total Station
LENSIMETER CL 200 SHOWING INITIAL ERROR
My question topcon cl 200 lensmeter initial error problum
Apr 09, 2014 | Topcon Cl- 100 Auto Lensometer
Center bubbles will not level to center when it was turn to 180 degrees
Fix the instrument to a solid tripod. Level the vial. Turn the instrument 180 degrees. If it is out of level. Adjust half of the bubble's error with the foot screws, and the other half with the 3 adjustment screws around the vial itself. Continue to go back and forth 180 degrees until the two sides match.
It will take some time to get the hang of. But is not hard to accomplish.
Jan 02, 2014 | Topcon At-g2 Auto Level
Topcon AG-30B Transit manual
The WEB:
Topcon AG-30 Transit - Mohave Instrument Co
www.mohaveinstrument.com/NewFiles/AG30B.html
This is the classic Topcon AG-30B engineers' transit. The AG-30B has glass ... and a photocopy of the owners manual are included, all for just SOLD. ABOUT US ...
Oct 10, 2013 | Measuring Tools & Sensors
Roland e86
my e 86 no sound,please help mi
May 11, 2012 | Music
I turn on the TI-86 and the entire screen is dark. What should I do?
Adjust the screen contrast. Turn on the calculator. Press and release the 2ND key, then press and hold the down-arrow key for a couple of seconds. If you go too far, use the 2ND and up-arrow keys.
Jul 06, 2010 | Texas Instruments TI-86 Calculator
I have no cable for my Roland E-86. Witch one sould i buy??? tank you.
If you mean power adapter, it is a 12 volt 2 amp one and I don't know which polarity.
Here is an Ebay seller that has them for the E86:
http://cgi.ebay.com/AC-power-adapter-4-Roland-E-86-E86-Keyboard-Synthesizer-/110432738764?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item19b64dddcc
If it is the audio cable you are after, just get a standard INSTRUMENT cable (not speaker cable) with 1/4 inch plugs.
May 30, 2010 | Music
The video dont work and error 86 comes up on the screen
The E86 error code is a hard drive error, remove your harddrive and try powering up. If it works without it, try reformating the xbox 360 harddrive.
THIS WILL DELETE EVERYTHING:
Settings > System Info and press Y, Up (left stick), Down (left stick), X, A.
If that does not work you may need to purchase a new harddrive, you can get them online, or in most stores.
May 24, 2009 | Microsoft Xbox 360 Pro System Console
TI-86 Calculator Problem
Most likely you're trying to graph a function while you have the stat plot turned on. Turn off the stat plot and try it again.
Oct 16, 2007 | Texas Instruments TI-86 Calculator
73 people viewed this question
k24674
jasbo
jasbo
