Question about Air Tools & Compressors
When I use my nailer IM250a after a short while its stops working
3 Suggested Answers
  • 10865 Answers
SOURCE: I was using my paslode IM250A nailer todat when
Hello. go to sears parts direct on google and you can order the part you need. J.
Posted on Jul 20, 2010
  • 1949 Answers
SOURCE: I have an Hitachi NT 65MA2 finish nailer. Will
no will load but jamm
Posted on Feb 06, 2011
My paslode IM250A when charging flashes red and green back and forth is that a bad battery
The battery may be the culprit but more common is the fan motor. When the fan motor fails it will alternate red/green. The part is pretty expensive and is fairly involved to replace if you are not familiar with the tool.
Paslode nbsp900600 nbspImpulse Cordless 16 Gauge Angled Finish Nailer...
You need to remove the head cap, unplug the spark and fan wires, twist the fan assembly a few degrees to the left and it will lift straight out of the tool. Carefully remove the fan blade by loosening the tiny torx screw located on the side of the fan shaft being careful not to bend the fins.
Release the retainer on the top of the motor holding it in, unplug the motor wires and then slide it out.
Inside the motor housing is a plastic bushing that needs to be removed and replaced (part will come with the new motor).
Reverse directions to reassemble
Let me know if you have any other questions
Mar 04, 2017 | Air Tools & Compressors
Paslode IM250A nails jamb
Sounds like You need feeder spring. Is driver blade going all the way back up?
-Jeff
Mar 18, 2014 | Air Tools & Compressors
Bostitch MIIIFN Flooring Tool Problem
You broke a seel or dont have it plugged in to the air hose
Mar 15, 2012 | Stanley Bostitch MIIIFN Flooring Nailers
My paslode im250 will not punch pin home
The Paslode gas powered tools need to be thoroughly disassembled, cleaned, and lubed periodically. If you are running the correct gauge nails (16 gauge, straight finish nails for the IM250 and angled for the IM250A) and the tool appears to be working correctly then this is probably what it needs. I do quite a few of them here at my shop and it is the most common problem.
Feb 03, 2012 | Tools & Hardware - Others
Paslode framing nailer was working fine then stopped working and there is no led light. i put another battery in but still no green light. Jim
check the battery contacts in the body of the tool for corrosion or bent or broke, also clean the battery contacts with an eraser
Sep 20, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How cold is too cold to use this nailer? Also where do I get the 878226 sequential trip mechanism? Can I order on line? Thanks!
Any air nailer stops working at about 20 degrees
I have the part you need in stock
airnailerparts dot com
Thanks,
Yooper Jeff
Dec 08, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
WHEN I DRIVE A CLEAT INTO THE FEMALE GROOVE OF THE T&G IT STOPS SHORT OF DRIVING IT ALL THE WAY SO THE NEXT PIECE FITS SMOOTHLY. CAN U ADJUST THE DEPTH OF THE STAPLE? THIS IS USING THE BOSTICH MANUAL...
I assume you are hitting the driver square and hard. You can't baby a floor nailer. If hitting the driver is not the problem, the driver that contacts the nail could be chipped or broken. It's not unusual, especially if you've used it on hickory or maple. Compare it to a new one to see if that's the problem.
Nov 04, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Air Tools & Compressors Logo
117 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
