Question about Dewalt 3/8" Electric Drill D21009
I have a kawasaki 3076022 with 2 battery.how long will it tke to charge the battery. and how do i test the battery to find out if they are still good.
    Novelist:
  • 170 Answers
That's a factory question---put make/model number in the address bar in google---this will bring you to a factory site where you can research this issue-----GL
Posted on May 05, 2017
1988 Kawasaki VN 1500 Vulcan not charging
Hi, Wally before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads for viewing and printing that you will need please click on the blue links below. Good luck and have a wonderful day.
help 1500 not charging battery and other electrical issues
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
Jul 29, 2017 | 1996 kawasaki VN 1500 Vulcan Classic
I own Kawasaki G2 zx-6r the battery after a while seems to loose it's charge (it's got a new battery) it seems just fine for quite a while then looses all its power ? Can you please help me
Hi, John first perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for a drop in amperage then get out your test light and track down the short in that circuit.
5. Hook up a voltmeter to the battery and start the engine, if meter falls below 9.0 volts while cranking you need to perform a proper load test on the battery and replace if necessary.
6. With the engine running at 3600 RPM, the battery should read 14.3-14.7 volts if not continue tests.
7. Unplug the voltage regulator from the alternator at crankcase by the front of the primary cover.
8. To test voltage regulator go to https://www.youtube.com/watch?v=F8EjV0IjW9Q
9. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace the stator.
10. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace the stator.
11. With the voltmeter set on AC scale, both leads touching alternator pins meter should read 16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace the rotor.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Battery draining ZX6R Forum
Free Kawasaki Motorcycle Service Manuals for download
kawasaki ninja zx 6r motorcycle parts
Owner Manuals Service Manuals Kawasaki Vehicles
Feb 07, 2016 | kawasaki Motorcycles
2004 Kawasaki ZZR 600 charging system
Hi, Batman before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
To do this with a meter: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
3. On the other part of the disconnected regulator plug. Set the multimeter for Ohms x1 scale and measure for resistance across the pins of the stator. You should read something around 0.1 to 0.2 ohms for a 32 amp system.
4. Then check for continuity between each pin on the plug and frame/engine ground. The meter needle should not move (infinite resistance)(digitals will show infinite resistance) if the meter needle does move (indicating continuity)(digitals will show some resistance), recheck very carefully. If the meter still shows continuity to ground the stator is shorted (bad).
5. Set the meter to read A/C volts higher than 30 volts (the scale setting for voltage should always be higher than the highest voltage you expect or you may fry the meter). Start the bike, and measure from one pin to the other on the plug (DO NOT cross the multimeter probes! - touch them to each other). You should read roughly 16-20 vac per 1,000 rpm.
6. If the battery was good under load test, if the stator is NOT shorted to ground, and the stator is putting out A/C voltage, then the regulator is bad (most likely even if passed step 2)
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Test Your Battery in 10 Seconds Reliable Load Test with Only Multimeter
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
Kawasaki ZX 6R 2004 Service Manual
2004 Kawasaki ZZR600 Owner Manual
Dec 16, 2017 | 2004 kawasaki ZZR 600
2005 Kawasaki EL 125 Eliminator is not charging
Hi, Leedhurn before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
How to diagnose and repair motorcycle charging problems
Kawasaki Eliminator 125 Service Manual
2009 Kawasaki Eliminator 125 Owner Manual
Aug 27, 2017 | 2005 kawasaki EL 125 Eliminator
Bike wont start just a clicking
Hi and welcome to FixYa,
Initially, charge and load test the battery.
Offhand with a fully charged battery, jump the 2 big terminals of the starter relay. If the starter motor spins, then faulty starter relay.
Good luck and thank you for asking Fixya.
Apr 17, 2010 | 1990 kawasaki ZZR 1100
Kawasaki Vulcan 900 Custom - sat the winter,
Did you connect the poles correctly and are the bolts tight to keep good contacts?
Try usin a trickle charger to jump the battery.
Mar 21, 2010 | 2005 kawasaki EN 500 Vulcan
Kawasaki Mule 3010, keeps getting flat battery, wont jump start
Sometimes when the battery keeps going dead like that, a component may be creating a current draw. you can do a simple current draw test with a fluke meter by setting the meter to read amps, make sure the test leads are in the proper portals on the fluke for an amp test, and disconnect one of the battery cables and connect the test leads in-line with the battery and cable. It would help to know you have a good fuse inside the fluke. They are easy to blow, and whatever you do, DO NOT try to start the unit with the meter hooked up for the amp draw test. That is how fuses are blown. With the key off, check for any amp draw. If there is, you can start unplugging components until the draw goes away. If there was no draw to begin with, you may have a stator coil (or alternantor, whichever it has) that is weak and can't keep up.
Jun 01, 2009 | 1990 kawasaki ZXR 750
My charging system isnt charging on my Kawasaki
have you tried testing the regulator rectifier i am sure this has an effect on the charging circuit also is it definetly the charging circuit not working or could the battery be not holding the charge thats put to it.
Apr 21, 2009 | 1998 kawasaki KDX 200
Dewalt 3/8" Electric Drill D21009 Logo
330 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
