Question about LG Washing Machines
How to reset the washing speed of the LG machine. It washes too slow on favourite settings
  • 3 Answers
SOURCE: LG washing machine
the Play/Pause button? Check if you have Child Lock on? (Hold the Pre Wash button for three seconds to turn it on or off.
Posted on Mar 14, 2007
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
SOURCE: LG Front Loan washing machine
If your LG is similar to mine, there could be water in a hose that is located behind the small door on the bottom front of the washer. Open the door and drain the hose. Be sure to have a bowl or pan to let the water run into. Once the water is drained hopefully the washer door will open. When i brought my washer this was one of the selling features the sales person told me about.( The door and hose are accessible to the consumer to prevent them from having to call for a repair) Hopefully this will be your only problem. I bought an LG washer on June 28, 2008. It is now August 21st and my machine is still broken. It broke the FIRST time I ever used it (July 13th) and it still has not been repaired. (Per the repair person it is a water sensor problem which has been "ordered") I wish I had purchased another kenmore instead. I had my kenmore 16 years and never ONCE has a problem with it. I simply wanted to update my laundry room. WHAT A MISTAKE for me to purchase LG!!!!
Posted on Aug 21, 2008
ngfam1
  • 639 Answers
SOURCE: washing machine wont start on any cylcle,
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
How do i repair a lg washer that makes a grinding noise when slowing down from spin cycle
It sounds as if the tub bearing on your machine is faulty. To replace this bearing one needs to basically strip down the entire machine.
Not a job for a novice.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
I have a LG WM0642HW washing machine. During the wash and rinse cycles the machine runs really rough and will not turn the drum over. Sometimes the machine will stop and go into the LE error. I have...
Your problem requires very skilled LG technician to check the wiring circuit from the control board to the motor and hall sensor. Very possible that the control board is bad but highly unlikely. Suspect the wiring harness with high resistance to the motor.
Good luck
Jun 16, 2011 | Washing Machines
My Lg washing machine is not intaking water supply
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 30, 2010 | LG Kitchen Ranges
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
GE 5500 washing machine TERMS
These are the agitator and spin speeds.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
House circuit breaker trips when machine is set to delicate wash
Motor controller or motor itself has a short.
OR something stuck in the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 22422 Top Load Washer
I have a ge washing machine that on the spin cycle kicks on and off
Don't know the model but if it is a two speed model and is clicking off and on when set for high speed spin but seems to start up and spin OK in slow speed spin, you have a bad motor
Dec 19, 2008 | Washing Machines
LG WFT1391TP TOP LOADER WASHER PROBLEM
use stick to hit the kids - the booklet will leave them with the feeling they haven't been punished
Dec 12, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
