Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
My viking oven/broiler is not working. Nothing happens when I turn it on.
Krazytech
  • 725 Answers
SOURCE: ge spectra xl44
check your Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and /or Replace Electronic Range Control (ERC)
Posted on Aug 26, 2007
Krazytech
  • 725 Answers
SOURCE: Oven not lighting
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
  • 530 Answers
SOURCE: oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
Posted on May 28, 2009
  • 63 Answers
SOURCE: My GE Spectra gas oven worked fine last night.
Replace the lower igniter ($30).
Posted on Oct 11, 2009
Viking VGSC3676BSS oven wont light
Check the igniter and the burner near it - you may just need to clean it. If you try, you can probably even get to some point where you can observe whether the igniter is sparking in the gas path or not.
You may also be out of gas, the burners just running on the last dregs of gas in the pipes.
Aug 12, 2014 | Viking VGSC3676BSS
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Turn on oven and broiler comes on.
If the broiler burner is the only burner, then it should come on. If there are two burners, chances are the broiler burner comes on to get the oven heated up more quickly. Once near temperature, the other burner maintains temperature.
Check your owner manual to confirm.
Jan 15, 2009 | Viking VGIC305-4B Gas Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
30 inch Viking ultraline stove, 6 years old. You have 2? burners on the bottom in the oven. One on the right "buffs" or seems to go out then reignites. The "cook" also says it takes...
We inherited a 30 inch Viking Ultraline when we purchased our current house. I was extremely excited to cook on such a high-end range, but this thing has been nothing but trouble. The temperature on the oven is always between 25-75 degrees hotter than indicated on the dial. An oven thermometer is the way I solved that problem. None of the igniters work on the burners (I use a BBQ lighter on all the burners) the broiler has never worked, and one of the hinges broke and required replacement. We actually ordered the hinges off the internet for $25 each and replaced them ourselves--it was not complicated but would have been costly to get a tech out to do it.
After repairing the hinges, I decided to use the self-clean function, which, big surprise, not only did not work, but locked me out of the oven! I tried re-starting the self-clean, breaking the circuit and re-starting it and nothing worked. Having read many posts on the internet, I realized I would probably have to get a tech in to fix it for me. In desperation, I finally turned the oven on to 325 for 20 minutes, hoping it would unlock, and inexplicably, an hour after I turned it off, it unlocked itself. Finally, the burners are impossible to keep clean--no matter what I do to clean them, they always look filthy.
I would never buy another Viking product, as I am totally underwhelmed by the performance of this range.
Apr 21, 2008 | Viking Kitchen Ranges
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
387 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
