Question about Dualit Kitchen Appliances - Others
My dualit 2 slice toaster is new and just stopped working. the timer works but the toaster is not getting hot. The light comes on and all seems fine except for the toasting part.
Richie_asg1
  • 1036 Answers
SOURCE: dualit 20247 2-slice toaster
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This is operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Posted on Jun 25, 2008
  • 37 Answers
SOURCE: Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
SOURCE: Hi our 3 slice dualit toaster gets stuck when you
We have the same problem and it has been on all day, and credit to the toaster it has not yet burnt out an element, I am looking to replace the timer as I found that the pivot inside is on a plastic bearing and that has worn, I did find a timer on a web site but cant find it now.
Posted on Jan 01, 2010
espressonist
  • 1711 Answers
SOURCE: broken timer
The timer is also an electrical power switch and it can not be fixed. In any case and for safety reasons also you need to replace it.
It can be easily removed by removing the bottom panel and remember to make some notes on where each wire is connected so you will put them back in the same order with the new timer switch.
Good Luck
Posted on Apr 02, 2010
espressonist
  • 1711 Answers
SOURCE: The timer on my dualit toaster works and then
Unfortunatly this a very popular problem with the timers and the only solution is to replace the timer knob complete.
Their are in ebay and amzon com, very good price and they wll arive to you in a couple of days.
Posted on Sep 01, 2010
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
Timer stopping
Dualit Limited
County Oak Way
Crawley
West Sussex
RH11 7ST
  • Telephone: +44 (0) 1293 652 500
  • Fax: +44 (0) 1293 652 555
  • Email: info@dualit.com
  • FAQS can be found at http://www.dualit.com/support/2-slice-newgen/faqs#question2 and new timers can be ordered.
    May 25, 2010 | Dualit Vario 2 Slices Toaster
    Mar 24, 2010 | Dualit 20247 2-Slice Toaster
    The timer has failed on my dualit 2 slice toaster. where can i get parts?
    Nov 04, 2009 | Dualit 20295 2-Slice Toaster
    Dualit Toaster won't heat on either side.
    You may have awire that has burned off or the control switch is bad. You can get to their site by typing in "dualit" under google and you will get a lot of information and the web site.
    Feb 06, 2009 | Dualit 20247 2-Slice Toaster
    Timer does not work
    service center, get any part you need:
    Electra-Craft
    41 Woodbine St
    phone 201-439-1700
    fax 201-439-1701
    Nov 08, 2008 | Dualit CTS4E 4-Slice Toaster
    Electra-Craft
    41 Woodbine St
    phone 201-439-1700
    fax 201-439-1701
    Nov 01, 2008 | Kitchen Appliances - Others
    Faulty timer
    Dualit service center:
    Electra-Craft
    41 Woodbine St
    ph 201-439-1700
    Jul 12, 2008 | Dualit 20247 2-Slice Toaster
    Buy and fit a new timer switch.6 screws to remove bottom cover, pull the knob off and 2 screws hidden by the knob will be revealed, these hold the timer in. Make sure you put the wires onto the new switch in the same place you took them from.
    May 08, 2007 | Dualit CTS4E 4-Slice Toaster
    Kitchen Appliances - Others Logo
    65 people viewed this question
    Top Dualit Kitchen Appliances - Others Experts
    Ross Keen
    Piyal Perera
    Piyal Perera
    Joseph Hoffmann
    Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
