SOURCE: Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
SOURCE: slo blo fuse for Hafler DH100 preamp
Hi sheffster
Hehehe I am a Brizvegas , but I know what you are on about.. . Hard to find such a low value of fuse, if you mean a 1/16amp device You can get an 80ma from Farnell Electronics. in Australia by mail order.
What markings are on the fuse itself?
How long is it? 3/4 inch or 1 1/4 inch
It just seems a very low value, particularly for a sloblo. Good luck, hope you get the old girl fired up again :)
regards
Graeme
SOURCE: Definitive Pro-Sub 1000 subwoofer replacement fuse.
Fit a 3 or 2.5 anything lower, if you can get away with it, but nothing higher.
However the chances are that it blew due to an overload, often caused by a shorted semi-conductor acting like it was a piece of wire. So even fitting a smaller one and it blowing again doesn't mean it's due to the rating.
SOURCE: The mini fuse(2A/240v) keeps on blowing up on the
You can tell a lot from what the blown fuse looks like. If it's all black or even shattered, it's likely a short circuit somewhere. If it's just blown, then you have an overload.
Another way to find out is by figuring out when the fuse usually blows. If it blows when it's tapped, shaked or moved then you have a loose wire that's touching somewhere it shouldn't.
If it blows when you turn it up high, it might just not be able to handle that much power. Remember to ALWAYS turn down amplifiers when you hear noticeable distortion. Or, the sound pressure from the speaker might be jostling things inside the cabinet.
If it blows when you plug it in/ turn it on/ start using it you've got an electrical problem, not a mechanical one. You'll need to get the multimeter and start tracing faults.
