Question about Compaq Computers & Internet
Would like to use Compaq ps 4000 as a external power supply. please let me know what wires do i have to jump,to turn on power supply. Thank you..
    Master:
  • 467 Answers
Find the green wire in the ATX plug and jump it to the black wire right next to it
Posted on Jan 10, 2017
Power supply damaged, Can I replace it with any other model power supply?
A standard ATX PS won't fit in your low profile case. The plug types can be different too. Usually there's a schematic with a PS that describes the wire color of each voltage. So you could conceivably shove the pins out of one PS plugs and insert them into the different plug, or solder the wires to the correct pins, and leave the PS outside of the case.
Nov 16, 2013 | HP Compaq dc7600 Small Form Factor PC...
How to know Compaq ATX Power Supply PS-7171-1CF1 colored wires voltage representation?
Technical Reference Guide
For the
Compaq Deskpro EX/EXS Series of Personal Computers
pdf_27652.pdf . Section 7.2.1 3.3/5/12 VDC DISTRIBUTION
Jun 04, 2011 | Computers & Internet
I have a smps(model compaq PS-5500-1C). How can check its out put volatage?
Hello Anvar, hi, to run the power supply on its own, you need to short the green wire with the black wire. (plug in the unit)
using a Volt meter, select a range of DC 50V. put the black probe of the voltmeter to any black wire, and the red probe to the ff:
red is 5V
Yellow is 12V
orange is around 3.3V
Blue is negative 12 (switch or interchange the probe to properly read 12V on the voltmeter)
White is negative 5.
Visit this site for more information:
http://en.wikipedia.org/wiki/Power_supply_unit_(computer)
Apr 26, 2010 | Compaq PS-5500-1C (244163001) 50-Watt...
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Dec 13, 2009 | Computers & Internet
My lap top r 4000 light up and fan works but no display could this be the battery I replaced the power supply today
Hook it up to an external monitor, if that works. Might need a new Lcd display or at least an Inverter. May be a pinched wire near the hinge of the lcd display.
Doubt it's a batter problem, plug in the power supply , take out the battery and try.
Oct 16, 2009 | HP Compaq Presario R4000 Notebook
COMPAQ 272776-001 Power Supply 200W
They all do, I believe, I installed a new one, into my computer system not long ago, are you sure your power supply is one that the computer can handle? You shouldn't have that much of a problem - I wouldn't go pulling apart the wires on the power supply, its made like that for a reason, what you could try is see if your power supply has seated properly, sometimes if your not working on a flat surface the power supply plug won't go in properly and will not be pushed in all of the way, try laying your computer on its side, and pushing in the plug also, each motherboard has a certain amount of plugs for example 20 and 24, some motherboards want it to be a 20 power plug and others want it to be 24 power plug, thats the plug thats connected to your motherboard, that I'm talking about. make sure you have the right number, and that the motherboard plug and the power supply plug match, basically have the same number of connectors, (I mean that little white plug at the end of the red,yellow,black, wires, I hope this helps. ps- I really had to push on the white plug to get my seated properly
Mar 05, 2009 | HP Compaq 175-Watt Power Supply
Computers & Internet Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
