Machine sounds like its tryig to work but wont also when you put silver lid down it doesn't clic
4 Suggested Answers
  • 572 Answers
SOURCE: washer wont work
u dammaged the door switch
Posted on Feb 07, 2010
  • 32 Answers
SOURCE: the washing machine button that
We need to determine if you have a magnetic switch or a manual switch.
1. Do you see a finger-like object, or tab, sticking out from the underside of your lid and a hole in the body of the washer where that tab should insert to connect with the switch? If so:
1. insure the tab is there, not broken off or shortened, and that it has something within the small hold to connect with, a lever of some sort. Try sticking a screwdriver in the hole and starting your washer to start operation. If it works, you may need to replace the tab.
2. If you have a magnetic switch, you won't see a hole, but you should see a white, rectangular magnet case tucked under the inside of the door. When you close the door, you should hear a slight "click". If you don't, you may have a bad lid switch to replace. Or,
3. Insure your door is straight and not twisted, bent or warped and is allowing the door to properly sit on the switch. One common thing that happens is that something heavy has been set on the lid and it has popped inward, leaving it somewhat concave in the middle, raising the edges of the lid and not allowing the switch to connect. Simply push or tap the middle of the door from the inside and pop it back into shape. This should give the lid a bit of a hump on the outside and bring the edges and the switch parts down and together.
For further trouble-shooting, I'm going to need the make and model number. The make should be located on the console or top. The model number will be located on the inside of the lid or on the back of the unit
Posted on Aug 02, 2010
KAComstock
  • 274 Answers
SOURCE: Hello, My Yamaha YZF600 motorcycle wont start.
Hi there jfdnet! Yeah if you hear the relay operating and the starter is getting no juies then you need to replace the realy. First i would check you see if you get power to the starter. Use a light tester to check the hot wire on the starter and if you do have power the starter is bad. If you have power going to the relay but not going to the starter then the relay needs to be replaced. It is always good to use a light tester of multimeter to back track from the problem to find the source. Example: You turn the ign. switch but the starter wont turn, start with the tester at the stater them back track up to the ign. switch. Eventually you will find where the power hits a "brick wall" of a faulty part. I hope that this helps you out. Post any more questions you may have.
Posted on Apr 02, 2011
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Doesn't spin during spin cycle
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes.
PLEASE CHECK OUT THIS LINK, THIS WILL HELP YOU OUT COMPLETELY.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Hope this helps. Mike
Oct 20, 2011 | Kenmore 24032\24036 Top Load Washer
It wash and evacuate the water but doesn't spin at the end!! What can I do?
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Sep 09, 2011 | Washing Machines
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Machine fills up with water, goes through the agitate cycle then stops and wont go into next cycle
Your Lid latch switch is most likely broken, you will need to replace it, you can not bi pass this switch. you can order it from your closest appliance distributor.
Unplug or turn off breaker to washer.
Replace by removing front panel, should be 2 screws at the bottom of washer.
Slide and depress lid latch down to release.
unhook wires and reinstall the same.
May 07, 2011 | Kenmore 22422 Top Load Washer
Washer wont start
If the machine fills with water normally but then just sits there, you might have a bad lid switch - that's the safety interlock that won't let the machine start unless the lid is closed. Check the switch and also make sure the lid engages it when you put the lid down. Of course there could also be a problem with the motor, but first check that switch.
Mar 08, 2009 | Roper Washing Machines
Disk won't spin
My sons playstation 2 went to browser and after reading the only one solution of putting a cup on top of it, we did try that but we found that the problem was the silver piece had moved, so after we moved the silver piece toward the middle toward where the disk goes, then closed it, and put a little pressure on top and you could feel it turning , then we opened it back up, the silver part had moved back again, but the playstation started back working then without any pressure.. so my suggestion is move the silver part close to where the disk goes.and it will move itself back....It sure worked for us..I was beginning to think money down the drain for this playstation 2....thank God it worked so maybe it will work for you...
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
Washing Machines Logo
Top Washing Machines Experts
