Question about Canon Office Equipment & Supplies
Canon ir 105 without finisher machine is working when i attach finisher panel is showing ready to copy when i press print key for copy machine doesnot stop it keeps on runnig it doesnt even make copy
SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1  or  -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
Posted on Jan 16, 2009
  • 32 Answers
SOURCE: Functional Problem SC321-00
the sc320 code would indicate that the polygon motor should be replaced. when you turn on the machine, the normal high pitch buzz will not be there the motor is not spinning up. that's the reason for the blank copies.
the sc321 code is a "no laser writing signal (f-gate) error". which would caused by the polygon motor not spinning.
replace the polygon motor.
Posted on Apr 03, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Posted on Jul 02, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
destom
  • 126 Answers
SOURCE: kyocera fs-2020d doesnt do multiple copies of documents
This message often shows up when the memory is full from one document (normally a large file) to fix it you have to add external memory
Posted on Nov 09, 2010
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
Aug 02, 2014 | Canon IR 3300 Digital Copier
Sometimes my ir2022n gets stuck and does not work but displays no errorso
THE FEED ROLLER THAT PULL THE PAPER IN MAY BE DIRTY. CLEAN THEM WITH ALCOHOL AND THEY SHOULD PULL THE PAPER IN.
Jun 04, 2012 | Canon iR 2022 Printer
Code E000001-0004 what is this code and how to fix.
this is error for abnormal rise of temperature, if it is not seriuos ( I mean nothing faulty ) you can reset it in service mode.
Procedure:
While the copier in copy ready or showing error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose:
COPIER
FUNCTION
CLEAR
ERR
Hope that helps!
Aug 23, 2011 | Canon imageRUNNER iR C4080 Color Copier
What it a finisher for canon ir 2520
it is the "device" which is mounted on ir 2520 or any other copier, with purpose to stack, collate or staple the copies. :-)
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
Canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
29 people viewed this question
old marine
old marine
