Question about Bosch Dishwashers
Bosch exxel dishwasher stuck on eco cycle - Bosch Dishwashers
SOURCE: Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Posted on Mar 28, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
SOURCE: my bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Posted on Nov 14, 2009
Can’t change the dishwasher cycle. It is stuck in eco and the arrows don’t seem to be operating
Sounds like control box is jammed.
It usually costs more to fix used appliances than they are worth.
I suggest upgrade to a new one.
Nov 02, 2017 | Dishwashers
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Tip
Conversion chart for dH to Clark BOSCH EXXEL Dishwashers
I couldn't find any info on my new BOSCH EXXEL dishwasher the codes in the manual are all in dH (german) while the H:XX codes mean nothing unless you have this table I created here it is for you all so you don't have to worry, it has all the conversions between Clark, dH and mmol/l and mg/l if you find one that applies to you just look across the table and find your corresponding H code.
You will need to go to your suppliers own website to find one of the above numbers for the quality of water usually in mg/l they will give you this value and then you can select the H code for you area.
Water hardness is measured in either European °E (clarks) or in the German °dH( Deutsche Härte) you will find this on all Bosch Dishwashers if you water is Extremely hard then you will need to program your Bosch dishwasher using the Code H:06 to give you maximum protection, if your water like mine is Extremely soft then the H:00 works well and also saves you loads of dishwasher salt.
HARDNESS CHECK TOOL
• Clark degrees (°Clark)/English degrees (°E) conversion to mg/L calcium: divide by 0.175 One degree Clark corresponds to one grain of calcium carbonate in one Imperial gallon of water which is equivalent to 14.28 parts calcium carbonate in 1,000,000 parts water.
•Deutsche Härte (German hardness) (°dH) conversion to mg/L calcium:divide by 0.14 One degree German corresponds to one part calcium oxide in 100,000 parts of water
on Dec 12, 2009 | Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
My bosch exxel wont drain ,can you help? thanks
Hi there, I fixed it , it was a cardomom seed sticking the impeller.
Dec 25, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Mar 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
395 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
