Question about Bosch Dishwashers
Hi - Bosch Exxcel dishwasher stuck on eco programme
  • 19 Answers
SOURCE: Bosch Exxcel MAXX dishwasher not taking any water
yes u got water on the bottom and there is a switch there first take the water from the bootom
Posted on Dec 30, 2007
  • 19396 Answers
SOURCE: We have an error message on our Bosch Exxcel
Hi Martin.
There is no Error H24 on Bosch machines. What the display is trying to tell is H2O, incorrect displaying may be caused by defective LCD display or board.
H2o is displayed when there is an inlet problem, either because water pressure is too high, too low, inlet hose is kinked or blocked, inlet valve is devective, or pressure switch is defective.
If you get problem only when selecting Intensive, which requires higher water pressure, then the problem can be pressure from the house lines, inlet valve blocked or pressure switch.
Let me know if this helped, in case do not forget to accept.
Posted on Aug 28, 2010
  • 19396 Answers
SOURCE: Bosch Exxcel dishwasher. Message E09 what does
E:09 is a fault detected in the heating circuit. Try first tripping circuit breaker (or disconnecting power cord) for five minutes and see if this can clear the error.
If that does not work, call Bosch at the number listed on the dishwasher manual. The repair is not suitable for the home user.
About E:09 I quote the good clarificatory explanation given by trikidik on this website.
"E:09 relates to a fault in the heating circuit. This new range of bosch machines do not heat the water in the same way as the older range. There is no water pressure switch on the heater assembly as the circ pump contains the heater in one complete unit (heat-pump). The control module monitors the speed & current draw of the circ pump to ensure that there is water in the sump & it is also circulating. Your machine must be less than 2 years old, so should still be under warranty. Its not a DIY fix, it needs an engineer to sort it, as it is probably a fault with either the heat-pump or the control module."
Posted on Dec 26, 2010
SOURCE: Bosch Exxcel Dishwasher operating instructions
What dose E15 mean
Posted on Mar 08, 2011
SOURCE: Bosch Dishwasher Exxcel error code 25????
error e25 check water on bosch dishwasher
Posted on Jul 01, 2011
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
178 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
