Question about Comcast Televison & Video
I need a remote code for a westinghouse tv model #sk-26h590d
Have the original remote that came with the tv & Comcast xfinity service
SOURCE: DirecTV remote control and Westinghouse
I used a Sony code 10111 that works. Sony makes components for Westinghouse.
Posted on Sep 01, 2008
pabloloco
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
SOURCE: I have an xfinity comcast
Code is 10463
Posted on Apr 02, 2011
jdvillanueva
  • 2098 Answers
SOURCE: owners manuel for westinghouse tv sk-26h590d
Hi Chuck,
You may download Westinghouse SK-26H590D User/Owner's Manual at this link (www.retrevo.com). When you are on the link, click "Download the Document", enter your email address and confirmation number, and then click "Download Now" to automatically begin the download. Manual is in Pdf file format, you must have an Adobe Reader to open the file. Just in case you don't have it yet, click this link to download and install it to your computer. After the download completed, run the set-up and then follow the wizard. The links I've provided are safe website, I used it personally.
Hope I helped you.
Have a nice day!
Kind Regards,
Jdvillanueva
Posted on Dec 19, 2011
Testimonial: "thanks jd, have a great holiday"
SOURCE: need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Posted on Dec 27, 2012
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
Jan 18, 2016 | Televison & Video
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
I can't link this remote from Comcast /Xfinity to my Westinghouse TV model EW24T7EW. Dose anyone know the codes as I tried pushing setup button and it blinks twice on tv and then I have tried (0000, 0
Some are 4-Digit and some are three Digit codes. I couldn't read all the codes you listed in the video description. I assume that these Comcast codes work for all Westinghouse model numbers. Hope this helped.
Sep 27, 2012 | Televison & Video
My Westinghouse 26H590D widescreen with DVD combo all of a sudden is messed up on color. It seems like the red is gone so human lips look blue, what I know from other tvs should be red come across yel
Looks like some dry solder, dry or leaky capacitors in board. Anyhow, first of all check and ensure that your input device, cables, connectors and jacks are ok and there are no loose contacts. Try working the TV on a DVD player and see. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Westinghouse SK-26H590D Television
Nuvision tv remote codes for xfinity remote
NVU55FX10LS use 10690 Comcast / Xfinity SILVER Remote with RED enter button
Jun 16, 2012 | Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
When I turn on my Westinghouse SK-26H590D with the remote it powers on I get a black screen with "VGA No signal" then after a few seconds it turns off and there is orange coloerd light instead of blue
This one might be a settings issue but I need more information to help you resolve this issue, please send me a bit more details or your contact information at westytech@wde.com so I can better assist you with this issue.
Nov 12, 2009 | Westinghouse SK-26H590D Television
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Televison & Video Logo
73 people viewed this question
Top Comcast Televison & Video Experts
Jay Plesset
 steve
steve
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
