Question about Sharp MX-M350 All-In-One Printer
Sharp mx m 345u not warmingup
Heater lamp turn on,heat roller is hot,all cooling fan running but expouser lamp not turn on and no display LCD
marsrover
  • 682 Answers
SOURCE: LCD overheats then the lamp turns out
clean all filter and do not block any ventilation slots with any objects and check .if the problem exist contact service center for help.
Posted on Mar 22, 2008
  • 126 Answers
SOURCE: we have sharp AR 206 F502 code is coming what is this code
F5-02 - Exposure lamp blown
**ALWAYS DISCONNECT POWER BEFOE WORKING ON MACHINE****
Check the exposure lamp, if defective replace.
Check inline exposure lamp fuse, if defective replace.
Also check flat cable from CCD to MCU PWB , if cut or defective replace.
Last -- brds (boards)
Posted on Feb 01, 2009
  • 72 Answers
SOURCE: My sharp R-1480 does not heat up. The fan runs
check the door switches and magnetron
Posted on Feb 06, 2010
  • 33 Answers
SOURCE: i have sharp mx 2700 .mechine is working but no
Most likely the back light is blown out....try shining a flashlight down on to the displat and you might be able to see the display but this will reqire a qualified tech to repair
Posted on Jul 20, 2010
heatman101
  • 43501 Answers
SOURCE: MICROWAVE RUNNING. DON'T HEAT & TURNTABLE WON'T TURN
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yteyyew
Posted on Sep 30, 2010
How do I change heat to cool?
Hi Annette, it's Jack at Dyson.
When you lower your AM05's target temperature (shown on the LED display on the front of the machine) down to 0°, the red light around the on/off switch will turn blue. This shows your machine is now running in fan-only mode, without the heating elements - suitable for use in hot weather. You can then adjust the airflow power and oscillation to suit your needs.
I hope this helps. If you need any further advice, visit www.dyson.com and click 'Support'. Or if you'd like to speak directly with our experts, you can reach the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 09, 2016 | Dyson AM05 Hot Cool Fan Heater
Sharp Mx-M453u......No display No power on panel display,but Mother board,MFP board light on and cooling fan running
Check the power supply for the presence of all the voltages it supplies to the other circuit boards.
Nov 15, 2015 | Sharp Mx-M453u mx-M453u
Code h 4 in sharp photocopier model ar5520n
Description Heat roller low temperature detection
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing." Causes Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality
Aug 08, 2015 | Sharp MX-3610N Color Photocopy, Print &...
My days on heat/ cool fan won't start on cool
Hi there, it's Jack at Dyson.
To run your Dyson Hot + Cool heater on fan mode, you need to turn the target temperature down to 0 degrees using either the remote, or the controls on the base. The target temperature is shown on the LED display on the front of the heater. When fan mode is activated the light around the on/off button will turn from red to blue.
I hope this helps, but if you'd like any further advice you're welcome to contact our experts 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
H5-01
There is a paper jam most probably in the fuser unit. This causes the heater lamps delay in heating the fuser roller at the required time.
Feb 21, 2011 | Sharp MX-2300N Color Copier
My sharp ar 275 has a problem h4-00. what can i do ?
Hi;
H4-00 Heat roller low temperature
detection
If the heater lamp blinks normally:
Check the thermistor and its harness.
If the heater lamp does not light:
Check for heater lamp disconnection and
thermostat disconnection.
Oct 19, 2010 | Sharp AR-M205 Copier
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
Nov 03, 2009 | Sharp SF 2020 Copier
Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
Jan 21, 2009 | Sharp AR-M162 All-In-One Laser Printer
Auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Sharp MX-M350 All-In-One Printer Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
