Question about Pool & Spa
How to set carboureter on jamaha 115 outbord moter
2 Suggested Answers
captainjeffq
  • 52 Answers
SOURCE: the fuel mixter
Should be 50 to 1. a call to any mercury outboard dealer will give you the exact ratio
Posted on Apr 14, 2009
How to set timing on 60 hp mariner outbord motor 87 model
You're not asking about a cell phone, are you? You might want to repost this question in a more appropriate area of FixYa, and specify the make and model of whatever device you're asking about when you do.
Nov 30, 2013 | Cell Phones
Got a jamaha xj650 turned over once and now wont,,,battery's full, lights etc ok.
Have you tryed turning it over with a spanner on the crankshaft
Sep 17, 2011 | 1982 Yamaha XJ 650
How do I set the Waterway Champion Pump for 115 Volts? I have the same problem, just installed and it runs for a bit then shuts off. It was mentioned that the pump is usually set for 230, so how do I set...
The voltage is not optional. What voltage are you plugging the pump into?
If you are plugging it into 115, the pump must be set for 115.
If you are plugging it into 230, the pump must be set for 230.
Usually there is a wiring diagram on the label on the pump body or if you remove the end cover, there may be instructions there. There may even be a switch or terminal that states 115 volts and another that states 230 volts.
Gary
Jun 29, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
I want to know the carb setting on my jamaha jog 50 i put a new piston in and wen i rev it it sounds like its choking and doesnt move very fast
Its complicated to tune the carb for a 2 stroke engine! As u have said, u recently replace the piston!
better go to Youtube for a complete step by step procedure in tuning that fine engine! type the scoot... let it search for u!
Hope that helps u out!
Jun 13, 2011 | 2008 Yamaha JogR
Yamaha outbord motor will not idle up it did when i first started it but a buzzer came on and it stop revving up
The buzzer is the chock on you may need to manually release it.this should fix your problem
May 08, 2010 | Boating
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
The fuel mixter for a 90 hp tracker force power serise outborde moter
Mar 27, 2009 | Boating
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
