Question about Garden
How do I get the head off a Trim Teach 750 tl weed eater?
bbreton
  • 437 Answers
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Posted on Feb 25, 2010
  • 61 Answers
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Posted on Apr 29, 2010
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
  • 36 Answers
SOURCE: weed eater bogs down when i try to give it full
have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Posted on Sep 22, 2010
kjhbegrt
SOURCE: Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Posted on Jan 10, 2015
How do I remove the head off my bolens bl110 weed eater
if you want to put in new trim line
the knob is left hand thread so to get it off you will have to turn it as it you are doing it up
if you want the whole head of the shaft , there will be a clamp/screw/retaining bolt that you remove and pull the whole lot off the shaft
Apr 29, 2017 | Garden
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How to line the feed on Stihl FR 106 Weed Eater Max 420 head
    could you add a picture of the particular head you're using.
    Aug 22, 2014 | Stihl FS 85 Weed Eater
    How do I remove the spoolhead so as to afix the pivotrim head
    I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
    Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
    Enjoy! :-D
    Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
    Apr 27, 2010 | Ryobi Garden
    Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
    rotate attatchment head slightly while inserting driveshaft
    Jul 30, 2009 | Garden
    Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
    Poulan Weed Eater Trim Line Constantly Jams
    Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
    Jim
    Jun 13, 2009 | Poulan Garden
    Need to add new string to a weed eater xt 12
      For manual go to;
      http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
      Preparation Instructions
    1. Press the lock and rotate the spool counter-clockwise.
    2. Remove the locking ring if your weed eater has one.
    3. Take off the automatic feed button.
    4. Wipe away any debris.
    5. Push down on the spool to release the locking tabs.
    6. Remove the spool from the chamber. Restringing the Weed Eater
    7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
    8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
    9. Secure each of the lines into its own upper and lower deck grove settings.
    10. Install the spool back into its chamber.
    11. Pass the lines into the left and right holes and snap the spool into place.
    12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
    13. Reinstall the locking ring if necessary.
    Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
    Jun 01, 2009 | Garden
    Garden Logo
    42 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
