Question about Vizio Televison & Video
Will replac cement remote xrt010 work with Vizio TV model e321vl
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I need to program my remote the tv vizio E321VL
If the set does not turn on:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Posted on Jun 03, 2012
jeffthern
  • 3 Answers
SOURCE: Need Vizio E321VL TV Stand Screws
I have a M420VT Vizio TV. I used (4) M6-1.0 x 16mm screws to attach the stand to the TV stand adapter. The screws I used to attach the adapter to the TV were (3) M4-0.7x12mm. It worked out perfectly!
Posted on Jul 27, 2012
SOURCE: Replacement for remote control for Vizio T.V.
they are on ebay for as low as $9.99
Posted on Nov 25, 2012
Model E321VL. Where can I get a replacement power cord?
You can get a replacement power cord from several sources. Sears has this one with a right angle at the TV for ease of cable routing: http://www.searspartsdirect.com/model-part/e321vl/3296/0333600/50040978/00001.html . Based on the pictures of the power board, I believe most older computer monitor or desktop CPU power cords will work. In the U.S., these usually have NEMA 5-15P to IEC C13 ends. Cyberguys.com has several options, including this: http://www.cyberguys.com/product-details/?productid=541&rH=1529 .
I hope this helps.
Feb 20, 2016 | Vizio Televison & Video
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
I have a all for one urc 3021b00 universal remote and i need the code for a vizio#E321vl tv
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7692/~/programming-the-one-for-all-urc3021-universal-remote-control-%283-devices%29
Nov 29, 2014 | Televison & Video
How do I make my remote work? It was working then it stopped. I thought it was the batteries, so I bought new ones but it still wont do anything.
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio XRT010 Remote for E320-A0 E241-A1...
Why do i need a code to my tv when my remote is the same name?
If the remote is the original remote that came with ( or is an EXACT replacement) you don't need a code. If the tv doesn't turn on with
the power button on the tv, then you may have a problem with the main board.
Samue
Camtek Of NY 718 527 6577
Sep 28, 2014 | Vizio L32 32 in. LCD HDTV
Feb 19, 2012 | Insignia Televison & Video
Televison & Video Logo
26 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
