Question about Refrigerators
Hai we have C80MX3-2RH CENTAC Compressor we tryed to start it but it trip off written Starter Failler what should we check ?
  • Refrigerators Master
  • 5,323 Answers
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER though seldom CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click.
Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS.
And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Some fridges are now using ADC boards.
Designers are using microprocessors (on solid state circuit boards) to adapt defrost intervals and durations to compensate for differences and changes in operating conditions. Such techniques are calledAdaptive Defrost Control, commonly abbreviated as ADC. Theu are normally found in same locations as the timer would be but look somewhat different in appearance. It is more difficult to test these units without the appliance schematic.
Some ADC / control boards control other functions of the refrigerator, too, such as icemaking and electrical air damper door opening and closing.The defrost frequency may also be shortened under certain circumstances.
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, sometimes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Posted on Jan 07, 2017
Do you think it could be my thermo stat making it trip on and off I want to rule out the relay plug and thermostat before I call a tech out and have to pay more money or compressor thx
The thermostat is a simple switch, it unlikely to be the stat but it,a not impossible, if it were arcing it could cause a trip. My guess is it's more likely to be the starter on the compressor or the compressor itself. If you know what you are doing and are qualified you could check the stat for leakage. (You could also eliminate it by bridging it out but I don't like the idea if it's tripping). Have you tried disconnecting the compressor to see if it still trips? HIGH VOLTAGES BEWARE
May 12, 2014 | Refrigerators
The fridge is not cooling,no fan noise but light on
Make sure that the compressor is working, You will need to take the fridge out and check the compressor motor for the start up on switch on > If not check the starter/contactor which could be defective and fitted to the motor. replace if faulty. Use a clamp tester or get help to finalise on this observation. Use a multimeter for checking for the voltage to the fan also. It might be possible that some rodents could have biten off your wires while you were out. so lets hope this is possible and so take a good look inside. If not check your compressor, starter. Good day
Aug 02, 2010 | Liebherr KIU 1640 Premium Compact...
I have a kenmore 25352642303 the frig is no longer cooling or freezing like it should.It will start and run for a couple of seconds then quit.Could the starter switch be bad on the compressor
possibly. But if it was completely bad the compressor would'nt do a thing. If you have a hard start cap. for a small appliance try that it's cheaper than replacing the switch just to find out your compressor is low on charge or bad all together. With a low charge the compressor will heat up and trip a thermal limiter. I believe your fridge is a sealed unit meaning a freon recharge is not really an option. If a hard start works, thenI would replace the switch.
Apr 30, 2010 | Refrigerators
How do I obtain a service manual for the COMPLETE C3II AIR END ASSEMBLY ({Airend 3ACII C255MX3 ? 9.1 Bar(A)} compressor?
not a service manual but a manual. To get the service manual you will have to contact the manufacturer, links in the manual www.iraindco.com/PDF/CENTAC/CENTAC.pdf
Mar 17, 2010 | Air Tools & Compressors
I have a Craftsman 25 Gal Air compressor that is about 15 years old ans all of a sudden it is tripping the breaker instantly on start up. nevr had this probplem before, every now and then it would trip the...
Try plugging something of similar amperage into same outlet, see what happens. If breaker trips, check wires in outlet box.
If not, start checking wiring in compressor, from plug back - ALL of wiring,
And scrutinize connections! Good luck! Joe.
Feb 14, 2010 | Craftsman Air Tools & Compressors
Compressor will not start, keeps on tripping with high amperes
Check the starter relay. If that's not it then the compressor is bad.
Feb 11, 2010 | Sub-Zero 642
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Apr 25, 2008 | Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
