Question about Siemens Washing Machines
Lock symbol on display Siemens siwamat xli 3640. Unable to select a wash programme.
Siemens siwamat xli 3640 - when I turn the selector, I only see a flashing key symbol and 700 rpm spin speed, unable to select another programme. Any advice please? I only have a Spanish instruction manual. Machine is ten years old.
    Top Expert:
  • Siemens Master
  • 51,484 Answers
Search google for english manual Google
Posted on Jan 04, 2017
My siemens siwamat xlp 1340 shows a lock key and wont operate
that means that the door catch is not operating properly you may need to replace the door lock yourself or call the washing machine engineer for a quote eric
Jan 13, 2018 | Siemens Washing Machines
Please tell me the part no. of Siemens Siwamat 266 timer and where can I find it. Can I get Service Manual for the machine?
https://www.download-geek.com/download/Manual+Instrucciones+Lavadora+Siemens+Siwamat.html?aff.id=9001&aff.subid=100
Sep 08, 2017 | Siemens Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Siwamat xli1240
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
Nov 11, 2013 | Washing Machines
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Nov 22, 2011 | Siemens WDi1640 Front Load Washer / Dryer
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Jul 17, 2009 | Siemens Washing Machines
Wash programme will not start
Start button is bad, the button it self, not the board
Jan 03, 2009 | Siemens WFXD8400UC Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
