SOURCE: LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
SOURCE: LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
SOURCE: I have a LG LD-14AW2 dish washer. it starts and
Hi glen bundese,
Yes it is the heater unit...
HE
means Heating Error - The Element needs to be replaced - Or the
Thermistor on it, though if the thermistor was faulty it would give a TE
error.
Both parts come as a unit (Usually). I would refer you to a
qualified L.G technician in your area
- Replace the element unit, and things would be OK.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful, please rate it.
SOURCE: E1 error on LG washing machine LD-1204W1
Hi gmann947,
*Nice nickname, reminds me of Jeremy Mansfield, a retired radio presenter on 94.7 fm - Hehe*
To help you with your request, I'd advise you to look at my Tip below, it has the full description on how to fix the E1 error:
L.G DISHWASHER E1 ERROR...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it.
This error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced if faulty, too much water.
