Question about Refrigerators
The icemaker is in a drawer - Refrigerators
KitchenAid KBFO42FTX04 bottom drawer frozen shut.thawed but refreezes in 3 hours.Ice crystals everywhere.Icemaker off.How is it freezing shut?
Your freezer drawer is not sealing 100% and room temp. is entering and causing your winter wonderland. The freezer drawer rides on two rails and these rails can get out of sync. One way to correct alignment issue is to open drawer all the way with a little bit of force. Next, close the drawer as fast and as hard as you can. I've used this to correct alignment issue. Sometimes the drawer will need to be removed and reset and other times you might have a bad rail. Good Luck
Aug 15, 2017 | KitchenAid Refrigerators
Putting the icemaker back in the freezer after fixing a defrosting problem. How do you install the auger?
Based on GE, it probably goes into the front dispenser area of the Ice drawer first, and "should" drop in. Try to line up the Auger drive section in the Ice drawer with the Drive fork of the motor. You may need to allow the drive to run while you carefully allow the Ice drawer to move into the right position to allow Drawer to move into rearmost position.
Mar 16, 2015 | Hotpoint Refrigerators
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
I have icicles all over my freezer. They started on the door under the ice maker. It is making ice but it won't come out because it the turning thing can't turn because there is solid ice in the bottom of...
Your icemaker is surely at fault. Shut the water off at the valve, turn off the icemaker, and defrost again. Does it happen again? If not, check your icemaker assembly for leaks or replace the water inlet valve if necessary. Good luck.
Apr 24, 2011 | Refrigerators
Icemaker on LG LFD25860ST not working.
Sounds like the hot gas defrost solenoid is enegised. the contoller for this may be at fault.
Apr 17, 2010 | Refrigerators
Ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Feb 23, 2010 | Whirlpool Refrigerators
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Feeler arm on ice maker prevents freezer drawer from opening
Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
Hope this helps. Please let me know if I can help further.
Vic
May 11, 2009 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
