Question about Refrigerators
Icemaker not producing ice. It is switched on but nothing
    Top Expert:
  • Refrigerators Master
  • 50,216 Answers
It has to have a water supply hooked up and they have inlet valves that need to open and close as needed .
Posted on Jan 04, 2017
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    The icemaker is not producing ice. Water is not going into the icemaker to produce the ice.
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Oct 30, 2010 | LG LSC26905 Side by Side Refrigerator
    GE side-by-side: freezer making grinding noise. Husband unplugged and removed icemaker. What was the problem and can I fix it myself?
    did it sound like someone snoring in your freezer? that is your icemaker trying to eject cubes, and that noise in and of itself, is nothing to be worried about, that is normal. however, if your icemaker was failing to produce ice, when your husband removed the icemaker, was it near overflowing with ice, or did it look like it just had what would be a normal amount, i.e., the ice in the mold was little more than helfway. if it seemed like it was a normal amount of ice, then the heater on the bottom of the icemaker failed, replace the icemaker. if you had an abundance of ice in the icemaker, you may have a problem with either your water vavle solenoid not closing completely, or the icemaker motor itself is slow, causing the valve to be open too long. without checking it personally, i cant advise either way
    Feb 15, 2010 | GE Refrigerators
    Icemaker doesn't work
    Icemaker seems to be working now.
    I think that moving lever and switching on/of helped. I see and hear that it is producing ice now.
    Jan 10, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
    How do you change the ice cube size on this model? I cannot locate the ice cube size button anywhere!?
    Hello there
    Normally
    You can't change the shape. or the size of the ice that is produced s It's determined by the manufacturer of the ice maker. but if you have the adjustment feature on your icemaker than pull the front cover off of the icemaker ande their will be a round adjustment wheel with different letters along the side these represent the different sizes of the ice that can be produced
    their should also be a diagram on the inside ov the cover that you just took off that will help explain the different settings ok
    I hope that this is very helpfull for you.
    Best regards Michael
    Nov 05, 2009 | LG Refrigerators
    Icemaker not producing ice at all. Tried all the
    hi
    it is the compressor problem ..check it
    thank u,,//please rate it
    Jul 04, 2009 | Whirlpool GS6NBEXR Side by Side...
    Icemaker is not producing ice
    There is a switch that turns it on or off. There may be a number of things wrong with it. Try tinkering with the switch. It should be a metal rod that sticks out.
    Jun 18, 2009 | KitchenAid KSRK25IL Side by Side...
    Ice not being produced
    hi there,
    check to see there is any frost building up, either on the water line or the inside of the door.
    if there is no ice build-up, you may have to have the water valve (inside the icemaker) replaced.
    Aug 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
    Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
    When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
    Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
    Refrigerators Logo
    27 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
