Question about Refrigerators
Icemaker not producing ice. I have pushed the on button but no results
  • Refrigerators Master
  • 5,323 Answers
ICE MAKER not making ice
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
God is the reason I give you free advice so God is good!
Refrigerator Ice Maker Not Making Ice www goodappliancesuperstore com
Posted on Jan 04, 2017
No crushed or cubed ice being produced
Ice tray may not be filling. Have a look under or on the side of the icemaker., Some have a little button to reset it. Press and hold the button in and see if the ice tray rotates and refills with water.
Nov 20, 2016 | Refrigerators
Icemaker is not working properly. It will only make ice after the reset button is pushed.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
Jun 21, 2016 | Samsung RF263BEAESR Stainless Steel 26 cu....
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    GE Automatic Icemaker Model ZDIS15CSSF, won't make ice.
    These units often have a hard-to-see reset button to resume proper operation. Look hard or check your manual.
    Jun 22, 2015 | GE Monogram ZDI15C Automatic Icemaker
    My samsung model RF4289Hars refrig ice machine wil not make ice now i pushed on the button then it said to push reset button where is that Gary
    The reset button should be on the icemaker, mine is a clear rubber button, I have my icemaker in the door so you fridge maybe different.
    Jun 09, 2015 | Samsung Refrigerators
    Lights on front of refrigerator seem to be locked. nothing works when you push one but lights are on and the temp area states the same 39
    You are looking at a bad selector switch and or the door switches that activate the auger to push the ice out. You would be looking at replacing the whole control if you need the ice to come out of the door. I would first try the simple unplugging and plugging back in, sometimes resetting the unit can help clear it up. Good luck
    Sep 09, 2012 | Refrigerators
    The icemaker is not producing ice. Water is not going into the icemaker to produce the ice.
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Oct 30, 2010 | LG LSC26905 Side by Side Refrigerator
    My icemaker stopped producing ice, do you think if I defrost it will it help
    check the fill tube and make sure it does not have any frozen water in it.also try and push the reset button and see what happens.
    Feb 20, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
    How do you change the ice cube size on this model? I cannot locate the ice cube size button anywhere!?
    Hello there
    Normally
    You can't change the shape. or the size of the ice that is produced s It's determined by the manufacturer of the ice maker. but if you have the adjustment feature on your icemaker than pull the front cover off of the icemaker ande their will be a round adjustment wheel with different letters along the side these represent the different sizes of the ice that can be produced
    their should also be a diagram on the inside ov the cover that you just took off that will help explain the different settings ok
    I hope that this is very helpfull for you.
    Best regards Michael
    Nov 05, 2009 | LG Refrigerators
    Ice maker not producing any ice.
    Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
    The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
    Do not replace the filter if water flow is good thru the dispensor .
    Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Refrigerators Logo
    22 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
