Question about Refrigerators
Icemaker is not making ice. I have pressed the on button no results
  • Refrigerators Master
  • 5,323 Answers
ICE MAKER not making ice
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the
clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Refrigerator Ice Maker Not Making Ice www goodappliancesuperstore com GE Refrigerator Ice Maker Not Making Ice Easy Fix and Repair DIY
Posted on Jan 04, 2017
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
Ice making not making ice
Cycle the icemaker with the reset button. It is located on the bottom-front of the icemaker. Press and hold for 8 seconds to complete a cycle. You should hear an audible reset tone from the refer when complete. If it still doesn't work later in the day, it may need replaced. These units are well known for deplorable ice making capabilities. Samsung considers 60-72 cubes per day to be acceptable. I consider it an insult. For the icemaker reasons alone, I am looking into another (domestic) brand.
May 30, 2014 | Samsung RF265AA Bottom Freezer French Door...
Replace ice maker still not making ice, it still dispenses water
Before suspecting the solenoid water valve, check the inlet tube, where the water enters the freezer. Sometimes this tube gets blocked with ice. From the back of the refrig, you can disconnect the water line where it goes into the back wall of the freezer and you should be able to blow air through it. (having the freezer door open while attempting this will prevent any back pressure build up) If you can not blow through it, it is plugged with ice. Melt the ice with a hair blower from the inside of the freezer. Ice blockage can result from water seepage past the water valve (generally requires replacement of the solenoid water valve) or the fill tube extention may be too long, resulting in the tube touching the end of the fill cup on the icemaker, which results in a build up of ice and blockage in the fill tube. (this only requires cutting the fill tube a bit shorter, so it does not touch the end of the icemaker's fill cup)
If you were able to blow through the tube, you have either a bad solenoid water valve, or the icemaker is not giving it power (generally only 6 seconds of power near the end of the cycle) which would mean a new icemaker, as replacement icemaker parts are not available.
Jun 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My icemaker went on the blink, found water all over kitchen floor now it will not make ice but the freezer functions great. Model number ED2FHAXB04
Sometimes the water inlet are of an ice maker for no reason will freeze up preventing water from reaching the tray and making a mess. What will happen is the ice maker fill tube on the back of the cabinet also freezes up. As a result the icemaker tries to cycle pressure then builds up in the plastic feed line to the fill tube. This pressure build up in a very "low pressure" plastic line causes that plastic line to push itself out of the press to fit connections (fittings) at the back of the unit or under the unit. Hence the next cycle it just ports water to the now open line causing water to go to the floor instead of the icemaker.
You can locate the source of the leak by simply following the plastic fill tube and re-insert it into the fitting. You still need to find the ice build up that caused the initial leak and melt that ice buildup with a hair dryer or a fan until it is clear. Once you clear the ice blockage (near the rear of the icemaker) it should work normally again.
Feb 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Eyes (fair to good shape)
#2 phillips screw driver
Lets assume it was working at one time right? And the FREEZER temp is BELOW 20degs
REMOVE storage bin to see icemaker.
LOCATE test button on underside or rightside of clear motor asembly.
(should be black)
Press until icemaker starts, then release button. Watch the tray twist and return to upright the should fill with water.
If icemaker did not Start by pressing the test button.: UNPLUG the frig or go the Main Service Panel to the house (BREAKER BOX) and shut off the power and verify NO LIGHTS INSIDE THE FRIG>
Remove the concealed screws holding the icemaker to the ceiling.
PULL the icemaker forward to release icemaker. Using the Flashlight
LOCATE the wiring harness on the ceiling. Look for the RELEASE and Squeeze and pull down. Inspect the electrical pins to make sure all pins are equal and secured. If all is well there?
I would order a Icemaker assembly first since it is the least expensive.
Good Luck and Cheers!
Seen It B4
Your Welcome
Jan 02, 2010 | Samsung RS2578BB Side by Side Refrigerator
I'm not making any promises. But after years of selling refrigerators, without having to call a tech...Make sure your freezer is at zero degrees, as the icemaker is activated by temp. not only time. Ice cream should be hard as a rock. Try setting your freezer colder; and don't do the human nature thing by checking every 30mins to see if it make ice. You'll just dump the cold air out. The bucket stays full of ice until the next cycle. That may be why it stalled.
Good Luck,
May 31, 2009 | Samsung Refrigerators
Ice maker stop making ice
I had the exact same problem after looking at the ice maker I saw that there was a test button I pressed the button and it started working again
try that!!
Dec 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice maker does not work
I had the same problem and even called a technician only to be told they would come out for $70.00.
I got a tip and learned that nothing was ever wrong with the icemaker. What you must do is turn the temperature up to the maximum for a period of at least 8 hours. Especially after changing the water filter or unplugging, power failure, etc. Once the icemaker is producing you can then lower your temperature gauge.
Sep 13, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
