I want details on case no. 203/12/2016 - Computers & Internet
How do I change the casing on my bose acoustic wave multi disc player
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Nov 21, 2014 | Bose Audio Players & Recorders
Remove the casing on a Philips DCB152/50 Micro Stereo (IPOD/USB/DAB/CD). I need to change the fan. I have removed all the screws and the case still will not budge without brute force. And I'm
Oct 21, 2014 | Televison & Video
Sir , when i finished formatting my pc i found no sound in it what should i do now can u tell me?
At most of these cases there is a missing audio device driver. Please clarify me the model for your motherboard (or the computer brand / model in case of a brand name pc) and the operating system you installed in order to give a link and details what to do.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Feb 01, 2011 | Computers & Internet
Audio jumpers missing. Where do I place them
I thing that you mean the jumper settings for the front panel audio. In this case these are the details:
In case you need further details you can take a look at the motherboard's manual at this official link.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
Thanks and regards
Stelios
Jan 01, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Do you initially have to buy maps for the a garmin handheld gps?
It depends on the specific model you bought and whether detailed maps were included. In most cases, a "general" map is included for free, but the free map is usually not detailed (no roads or only MAJOR roads, like interstate, but no city streets).
In most cases, YES you will to buy separate maps for your handheld Garmin GPS.
Mar 29, 2010 | Garmin GPS
Top screen won't lock
The solution depends on whether the damage is to the case or the hinge shaft. Either way this repair should not be attempted if you are not comfortable working with very small electronic devices. If only the hinge shaft is damaged you can get a replacement from here http://www.dealextreme.com/details.dx/sku.15853
If your case is damaged you may want to replace both the case and the hinge. Here is an example of a replacement case. http://www.dealextreme.com/details.dx/sku.8696
This YouTube video shows the process of replacing the case. http://www.youtube.com/watch?v=Z_sCoHGIpU0&feature=related
As I said it is a very intensive and delicate process but as long as you move slowly and have a steady hand it is doable by someone with basic electronics skills.
Mar 28, 2010 | Nintendo DS Lite Console
Hi i have a acerpower fv celon d running windows 2000
You should be able to change your tower case as long as the form factor is the same as the motherboard you have. The form factor is the description. Example: If you have an atx motherboard then you can remove it from your old case and install it in an atx case. You can do a google search on the make of your motherboard and this should give you the specifications. In order to find out what kind of motherboard you have you can remove the side panel of your case and look inside on the motherboard! Make sure you don't touch anything inside the case as you could do some damage, this relates to static discharge, I won't go into that now though. When you look at the motherboard the make and model number should be printed somewhere. Once you have these details do a google search. If you are able to locate your motherboard details online there should be details on the kind of hard drive you can install. I don't know if you have an old motherboard or a new motherboard but the ports on the motherboard for a hard drive are normally IDE (Integrated Drive Electronics) parallel port or a SATA (Serial Avanced Technology Attachment) port! The sata port is easier to install. You should be able to locate these details online once you put your motherboard make and model number in. You can of course post all the details here and someone might be familiar with that motherboard. Good luck. Andrew
Jan 16, 2010 | AcerPower FV PC Desktop
I CAN'T START MY GAMES ERROR 80020321
Just change the UMD case and try if it works. It is sometime that the case is broken and then umd case spins but the cd stays in the same time.
Mar 04, 2009 | Sony PlayStation Portable (PSP) Console
Identical project finder
This is my miniproject. so plz give the codeing of this my project
Nov 14, 2008 | Project Delta
Computers & Internet Logo
David Payne
David Payne
