Question about Kelvinator Dishwashers
Hi There I got a KD12 DSS-2 Kelvinator dishwasher. It doesn't wash the dishes properly.
Hi There I got a KD12 DSS-2 Kelvinator dishwasher. It go throughout the whole cleaning cycle and looks like it has done the job. Even switch off no problem and no error message. But when you open the lid to remove the dishes you discover that the detergent was not released properly in the bin and the dishes is not clean? You can see see there was a heating cycle. I then removed the dishes and let it run a complete cycle. The only thing I could pick up it is giving a thumping and grinding sound at some stage but still no errors and a complete cycle. Let me know what could be the problem?
    Top Expert:
  • Kelvinator Master
  • 49,207 Answers
Are you sure it is filling with enough water .
Posted on Jan 04, 2017
Testimonial: "Hi Ray Yes it is filling with water I have opened the unit at the back and found that the electric motor that is suppose to push the water into the tunnel for the blades to turn doesn't work/run at all. Could that be the motor cycle from the program that is not running or what can I do to test the motor?"
User manual for kelvinator extreme clean KD12WW
Need to check if Rinse Aid is not exhausted in the dispenser. It could also be necessary to increase the flow rate of rinse aid. Also make sure the dishwasher is heating water as some dishwashers use steam to dry. If heater is faulty the steam will not be there.
Apr 21, 2014 | Kelvinator Dishwashers
Sediment is collecting in the bottom and on the dishes. I have tried a cleaning cycle but it doesn't work.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Maytag 24 in. MDBH750AWS Stainless Steel...
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
Kind Regards
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
My dishwasher is not cleaning my dishes
Hi btoma313,
Find some info in the Tip below, on what to do if your dishwasher is not cleaning properly.
Kind Regards :-)
Jul 19, 2011 | Maytag Dishwasher
Washing Powder will not flush out well
Start by buying a box of brand name dishwasher powder like Electrosol or Cascade. Use only it, not a cheap generic powder.
Please post back here with the results of this step and we can take the next step if needed. But I bet the step above will take care of your main problem.
Apr 11, 2009 | Kelvinator MDB121RF Dishwasher
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
79 people viewed this question
Top Kelvinator Dishwashers Experts
P Scarbs
Level 1 Expert
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
